Subwoofer instal
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14469
Printed Date: May 02, 2026 at 12:04 AM
Topic: Subwoofer instal
Posted By: darkcure211
Subject: Subwoofer instal
Date Posted: June 04, 2003 at 6:27 PM
I have a 750 watt model 600d Directed audio amp.  I also have two Cerwin-vega subs.  One of these subs is and svc and the other is a dvc.  They are exactly a 12in. vega series 12d4 and a 12in. vega series 124.  How do you hook up an svc and a dvc to the same amp correctly?
vega man
Posted By: kidshamrock_200
Date Posted: June 04, 2003 at 7:42 PM
There is no correct way. You have two subs and a mono block amp, with one being dvc. That means no matter what one sub will have more power going to it. you never want to mix SVC, and DVC subs, you also dont want to mix subs that are different ohms such as a 4 ohm sub and an 8 ohm sub because once again one will always see more power. -e-
PAIN Hz
Posted By: esmith69
Date Posted: June 04, 2003 at 8:03 PM
I disagree with the comment about never mixing DVC and SVC subs.  Although in general I'd try to avoid it, it can still be done with a 1 channel amp.  The main thing is that each subwoofer's effective load on the amplifier has to be the same; as long as that is the case, the total amount of power going to each subwoofer is going to be the exact same, regardless of whether or not they're DVC or SVC.
You would need a DVC sub with 2-ohm voice coils wired in series (4 ohm effective load), or a DVC sub with 8-ohm voice coils wired in parallel (also a 4 ohm effective load), if you were looking to run the DVC along with your 4-ohm SVC sub.
OR, the DVC sub you have now (dual 4-ohm) will only work if your SVC sub had a single 2-ohm or 8-ohm voice coil.
You can fool around with RF's woofer wiring wizard to get a graphical representation of how series and parallel wiring is done, just keep in mind the diagrams shown use identical subs, not mix and match.
Ethan
Donate to the12volt.com
Date Posted: June 04, 2003 at 11:30 PM
Right, if he had a single 8 ohm sub, or a single 2 ohm sub he would be fine. As long as he can get the same ohm load on each sub he can run a single and a dual voice coil sub, but the problem is he can't. And it's going to be hard and impossible to find a single 2 ohm, or dual 8 ohm sub especially in that brand and model because they didn't make one. Another thing to watch out for is spec changes between the subs. sometimes the DVC versions will be slightly different from the svc models. When possible get subs that can play well together  -e-
PAIN Hz
Posted By: esmith69
Date Posted: June 05, 2003 at 12:30 PM
Completely agree with you shamrock on all of those points; I just wanted to make sure that everyone out there knows that it is technically possible, given you have the proper equipment.  but I think you're right he's gonna have a hard time finding a sub of the same model line to match up with, and so for his purposes it's not possible.  Thanks for the clarification.
Ethan
Posted By: wvsquirrel
Date Posted: June 05, 2003 at 11:15 PM
Here's another school of thought. Independant wiring isn't really recommended (like I keep saying to anyone who asks!). But if you're gonna do it, using a mono amp is the safest way I could imagine. So... If you wire each coil of the DVC independantly, then you are presenting two 4ohm loads instead of one 2ohm load. Wire the SVC to the amp as well and you're off and rolling at a 1.33 load (which the amp is stable at). Based on your specs, you should get just under 200watts to the SVC, and just under 200watts to each coil of the DVC. Problem solved posted_image
posted_image
Squirrel
"No more Cpt. Kirk chit chat"
