Adding An Amp To Factory Bose System?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14564
Printed Date: May 01, 2026 at 1:06 AM
Topic: Adding An Amp To Factory Bose System?
Posted By: carguy411
Subject: Adding An Amp To Factory Bose System?
Date Posted: June 07, 2003 at 9:37 AM
im a dding a sub amp to a factory 2001 Infinity QX4 with the bose system, should i get the PACSNI-35 line output converter??
and where should i tap it off right behind the radio or from the rear speakers?does it make a difference when dealing wiht Bose casue i kow that theres 1 amp and then a small little amp at each speaker?
please let me know the best way to do this
thanks
Date Posted: June 09, 2003 at 11:51 PM
can someone help me please im doing it this weekend and i have to get the parts thanks
Posted By: esmith69
Date Posted: June 10, 2003 at 12:39 PM
Not all bose systems have the amps mounted directly onto the back of each speaker;  but I don't remember in this vehicle for sure whether or not it has a multiple amp setup or not.  I do think however that there's an amp in the rear left side panel, and this would either be a subwoofer amplifier or a single amplifier for the whole system.  Either way you're gonna need to get the signal for your line out converter from here.  It can either be a full-range signal or a low-pass signal; if all things are equal I'd take the full-range signal, but if it's easier to get at a low-pass signal (for a factory subwoofer for example) then you might as well tap into that wire.
Also remember that if you're using a LOC that you need to be getting a signal that's already amplified;  so that rules out tapping in to the back of the head unit.  Technically that would be possible though, but you'd need a line driver to accomplish that.
Ethan
Donate to the12volt.com
Date Posted: June 10, 2003 at 11:34 PM
ok so go in the back left side behind the panel and theres hould be a speaker there to tap in to
thanks
