2001 cavalier
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14781
Printed Date: May 04, 2026 at 5:01 AM
Topic: 2001 cavalier
Posted By: gmcsub
Subject: 2001 cavalier
Date Posted: June 11, 2003 at 6:24 PM
Left front speaker wouldn't work, radio made deep bass sound then popped the fuse, now there is nothing and it pops every fuse. installed data chime harness is there anything else that has to be done.
Posted By: esmith69
Date Posted: June 11, 2003 at 7:06 PM
So was it the factory radio that blew the fuses?  Or the aftermarket one?
Ethan
Donate to the12volt.com
Posted By: gmcsub
Date Posted: June 11, 2003 at 7:07 PM
aftermarket there is no factory radio in the car
Posted By: djfearny2
Date Posted: June 11, 2003 at 7:28 PM
radio is most likely bad but it may be a speaker blown that will not let it fully power up and work so it blows the fuses to protect itself. trial and error test each speaker or first disconnect all speakers put a new fuse in and then see if it turns on without blowing fuse., if it does blow the fuse then radio is bad.. unplug radio and replace fuse if the fuse is good than your ok. but the radio is bad. also test each speaker with like a 12 volt dc battery put one negative wire on negative side of batt and pos wire on pos side of batt and if you get a pop the speaker should be ok but that does not def mean the speaker is ok.. listen to how they pop if one is really low sounding and the others are higher that than that speaker can be bad.
Jon
Installer/Help Technician
---coral springs florida---
Posted By: gmcsub
Date Posted: June 11, 2003 at 7:36 PM
every speaker worked fine until I shut the ignition off and then tried to start the car thats when it made the noise and started blowing fuses
