Solobaric S10D Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14813
Printed Date: May 04, 2026 at 10:20 PM
Topic: Solobaric S10D Wiring
Posted By: kenosha
Subject: Solobaric S10D Wiring
Date Posted: June 12, 2003 at 7:24 AM
      Could someone please confirm that I have selected the correct wiring method for my single Kicker Solobaric S10D. I'm looking for a 2ohm load, but the speaker specs are a bit misleading/confussing. They never actually state the impedance of a single voice coil. I think I may be making this harder than it should be.
Complete list of skeaker specs: https://www.kicker.com/images/manuals/SolodMan.pdf
Model: Kicker Solobaric S10D (old round ones)
Impedance (ohms): 2,4,8 <-------------------------------------------- hmmmmmm?
Max Amp Power: 450
Sensitivity: 87.6
Freq Response: 24-10
Rec Enclosure V: .66
Wired using following method:
posted_image
Will this give me a 2 ohm load, with this speaker?
Posted By: kenosha
Date Posted: June 12, 2003 at 10:28 AM
Posted By: bberman1
Date Posted: June 12, 2003 at 10:39 AM
What is the exact model # on the back of your sub? Also do you have a voltage meter?
Posted By: kenosha
Date Posted: June 12, 2003 at 12:50 PM
Unfortunately I don't have the subs here at my new residence yet, they are back in Wisconsin.  They are the S10D if that helps.
Yes, I have a $14 radio shack DMM
Posted By: bberman1
Date Posted: June 12, 2003 at 2:28 PM
Well without the model number I can’t tell you if it’s a 2, 4, or8 ohm model. And if I don’t know how many ohms they are then I couldn’t tell you how to wire them. But when you get them if you can’t figure out the ohms you can use a voltage meter to measure how many ohms they are. You can read how to measure the ohms here https://www.eatel.net/~amptech/elecdisc/ . But when you get them give me the model # and I will tell you how many ohms they are and how to wire them.
