2000 Jaguar S Type Head unit!
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14922
Printed Date: May 06, 2026 at 9:29 PM
Topic: 2000 Jaguar S Type Head unit!
Posted By: scottysalesman
Subject: 2000 Jaguar S Type Head unit!
Date Posted: June 13, 2003 at 10:17 PM
How do I remove this unit to gain access to the cd changer plug in the back of the head unit? Thanks, Scott
scottysalesman!
Posted By: esmith69
Date Posted: June 14, 2003 at 10:16 AM
found this from a PDF file that's for installing an aftermarket pioneer head unit and controlling it via the jaguar head unit.
Remove factory radio/console by removing (using trim tool or small flat blade
screwdriver) the three small trim panels from around the entire console unit.
The radio, cassette rack and heater controls are a combined unit and will be
removed as one.
1. This will then reveal 4 X 8mm bolts (1 Left, 1 Right and 2 Bottom) these will need to
be removed in order to pull the entire console unit forwards.
Hopefully that helps!  Here's the link to the PDF file
Ethan
Donate to the12volt.com
Date Posted: June 14, 2003 at 7:34 PM
can you e-mail me the file so I can download it?For some reason I can't open it.Says "file not available" Thanks, Scott
scottysalesman!
Posted By: esmith69
Date Posted: June 14, 2003 at 8:16 PM
hmm weird yea I see what you mean...but when I find it through google and click on it there it works....i guess google has it cached or something. do a google search for this phrase (put it in quotes) and it should come up with one result--the page you want. "This Interface is designed for use with the Jaguar S Type"
Lol u said to email you the file but you don't have ur email address listed, so....posted_image
Ethan
Posted By: Velocity Motors
Date Posted: June 15, 2003 at 10:03 AM
Jaguar_99_01_S_Type_OEM_Stereo_Removal.pdf
Just click the above link. I took the liberty to download the information before posted_image
Date Posted: June 15, 2003 at 1:50 PM
Thanks for your help! Got the file ,now to work!
scottysalesman!
