Using eclipse factory amp w/ apline dvd..
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15296
Printed Date: May 15, 2026 at 12:48 PM
Topic: Using eclipse factory amp w/ apline dvd..
Posted By: total_eclipse03
Subject: Using eclipse factory amp w/ apline dvd..
Date Posted: June 22, 2003 at 10:02 PM
hello people,
im installing an Alpine indash dvd player(model iva-d900) into a 99 eclipse gsx.  The car has the factory infinity sound system.  i bought the MITAH adapter to use the factory amp.  when i hook up the remote turn on wire from the Alpine unit into the adapter i blow the fuse for the amp.  Also the Alpine unit turns off when this happens.  What can i do to get around this so i can use the factory amp??? Can anyone help me???
Posted By: benci007
Date Posted: June 22, 2003 at 11:19 PM
if you bought the alpine from someone respectable (i.e., crutchfield, bestbuy, c city) then you should be able to either call them or find a tecnical support number - especially if you bought a special adapter for the problem. if you paid money for something, then someone knows how it works or can tell you why its not working. worst case, get a cheapie 2 channel amp to run it for like a hundred bucks.
