6x9" installation for contour
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15313
Printed Date: May 15, 2026 at 4:46 PM
Topic: 6x9" installation for contour
Posted By: Kadetheus
Subject: 6x9" installation for contour
Date Posted: June 23, 2003 at 10:48 AM
i was wanting to know if anyone could tell me a good way to get a clean cutout in my contour's back dash for some 6x9" speakers. i'm very unhappy with the back door speakers and i'm hoping that someone could tell me a good way to cut the back dash aluminum.
thanks for the advice
kade
Posted By: The Buzz
Date Posted: June 23, 2003 at 2:21 PM
All you can really do is take a 6 x 9 cutout template and trace it on the deck and cut out the hole with an airsaw or nibbler. Then you have to either mount the speakers on the cardboard deck material with the aftermarkret grill or find a way to perforate the factory deck and mount the speaker below. It can probably be done but would be kind of a pain.
Posted By: chevylove
Date Posted: June 25, 2003 at 1:56 AM
You have a couple options here.  You can either (a) Keep from cutting the aluminum at all and cut yourself an oval ring of MDF or something similar to fit the speaker size and epoxy glue the hell out of it to the underside of the aluminum and mount the speaker w/ short screws or (b) cut out the sheet metal wide enough so that the speaker frame fits.  I wouldn't suggest mounting the speaker solely to the deck.....that's a rattle box waiting to happen.   Now see the above post.  First off the factory panel is already perforated so don't worry about that and second if you do want to mount it underneath the panel just mount it from underneath the metal using the ghetto technique i mentioned earlier or after drilling holes in the sheet metal.
Drew   "Fuses are only 10 cents...go for it."
Posted By: esmith69
Date Posted: June 25, 2003 at 7:47 AM
Did you ever think about just replacing the 6x8s with some aftermarket ones?  A whole lot less work, and if done properly will sound about the same as a pair of 6x9s.
Depending on how thick the aluminum is in the rear deck, you may be able to use a pair of tin snips to make your holes (or to widen existing holes if there are any).  If it's too thick for tin snips then a metal nibbler, airsaw, or dremel-type tool with a metal cutter would probably do the trick.
Also one thing you might want to keep in mind is that as there are not factory speakers already in this location, the rear deck cover might not give you enough space underneath it to mount a speaker, without it causing the hole cover to bulge up near the opening you cut.  I don't remember exactly what the deck looks like so I couldn't tell you for sure what you'll be facing, but I wouldn't be surprised if once you take the cover off you find yourself with hardly any room to top mount a speaker.  In that case, bottom mounting (from the underside of the deck) if really the only other good option in my opinion.
Ethan
Donate to the12volt.com
Date Posted: June 25, 2003 at 8:35 AM
i was wanting the speakers in the rear deck because cars that i have heard with the speakers in the read deck sound fuller than the just 4 door speakers. as far as the front of my car goes i'm satisfied. it's nice and clear. but i can't seem to get satisfied with the rear and i'm satisfied with the mtx 8000 sub that i have. by the way, would a kicker 400.1 amp push a 12" mtx 8000 fairly well in a single voice coil?
Posted By: esmith69
Date Posted: June 25, 2003 at 11:12 AM
Yea that kicker amp will give you pretty good bass for the 8000.  Obviously the way to maximize the output is to get another 8000, then wire the two subs in parallel for the single 2 ohm load, and you'd have 200 going to each sub.  But in your case, 200 watts RMS to a single 12" thunder 8000 is still going to give you really good bass.
About the rear speakers:  just remember that to get that same kind of effect you're going to have to make sure the trunk is fairly airtight.  At the very least, make sure you put some foam around the edge of your cutouts before putting in the speaker.  Also try to plug up any other holes that you can find.  You don't have to go lining the entire trunk in a big foam seal, just try to fix the obvious holes as best as you can.
I don't know what year your vehicle is, but I saw some pictures of a 98 contour that had the jbl system in it, and the rear doors were insulated and sealed REALLY well  (photo w/speaker in place, and w/speaker removed)  I don't know if they only do that for the cars with the jbl systems or if all of them would be like that, but I just thought I'd throw that into the mix.
Ethan
