How do I know if my Alternator is 180 amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15324
Printed Date: May 15, 2026 at 9:19 PM
Topic: How do I know if my Alternator is 180 amp
Posted By: Sebastian018
Subject: How do I know if my Alternator is 180 amp
Date Posted: June 23, 2003 at 12:13 PM
HI My question is this one, I bought a High Output Alternator for my car he told me it was 180amp. How Do I know If its really 180 amp? is there any way to know?
thank you
Posted By: DYohn
Date Posted: June 23, 2003 at 12:57 PM
Short answer to your question: No.
Long answer: Look for the manufacturer's specifications.  You should have received some sort of spec sheet with the alternator, as it is an aftermarket unit.  If you, try the manufacturer's web site if you have the model number.
Posted By: bberman1
Date Posted: June 23, 2003 at 1:34 PM
You can take it to any alternator shop and they will be able to test how many amps it is putting out, also a lot of the chain auto parts stores now have testing equipment, and I believe they will test the output for free. However if you take it to a alternator shop they can also tell you how many amps your car is pulling with your system on and all that good stuff.
Date Posted: June 23, 2003 at 5:29 PM
ok. thank you
