Spec’s for 99’ Montero/Infinity sound?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15338
Printed Date: May 16, 2026 at 1:16 AM
Topic: Spec’s for 99’ Montero/Infinity sound?
Posted By: smitty225
Subject: Spec’s for 99’ Montero/Infinity sound?
Date Posted: June 23, 2003 at 2:22 PM
Anyone know what wattage this head unit pushes? I need to replace one of the midrage speakers and want to find something compatible.
Smitty
Posted By: esmith69
Date Posted: June 23, 2003 at 4:05 PM
Just make sure you get something that has the correct impedence and is the right size.  And unfortunately that can vary widely among similar vehicles and the only way to make sure you know the right impedence is by doing a resistance check on the speaker itself.  Or of course if it says on the back of the magnet the ohms then that'll work too.  And remember if you happen to look at component midranges make sure it's not one made for home use cuz those are usually all 8-ohm speakers.
You can probably get something sounding similar to the one that's in your vehicle from Parts Express or another electronics catalog type place.  Of course you can also get some from Crtutchfield or any regular car audio retailer, but they'll only sell you them in pairs, whereas the electronics catalogs let you buy single speakers.
Ethan
Donate to the12volt.com
Posted By: Velocity Motors
Date Posted: June 23, 2003 at 10:31 PM
Just to add to the post above. Chances are the OEM speakers are going to be rated close to 15 - 30 watts MAX power. Find something that will be low in wattage because if you get something that is higher wattage, they will sound like crap........ I gaurantee it.
