Amp install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15505
Printed Date: March 29, 2026 at 9:06 AM
Topic: Amp install
Posted By: drudy1
Subject: Amp install
Date Posted: June 26, 2003 at 9:02 PM
I would like to install a fosgate amp under the passenger seat of my 92 stealth but I am worried about  clearance height. Could I raise the seat by adding a washer or two under the mounting bolts?
Thanks.
drudy1
Posted By: ViperFreak_01
Date Posted: June 27, 2003 at 9:26 AM
I am not sure what the setup on the seats of a Stealth are, but if you are going to be raising the height of your seats, you may need to buy longer bolts...Just be sure you have a bolt that threads in completely...the danger would be not mounting the seat correctly...Not a pretty picture in a car wreck when the seats fly out...
