Mach 460
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=1552
Printed Date: May 06, 2026 at 11:39 PM
Topic: Mach 460
Posted By: ott7283
Subject: Mach 460
Date Posted: June 27, 2002 at 10:14 PM
I'm trying to add an aftermarket head unit to my '99 Mustang w/mach 460.  I have a OEM converter because the deck is high power.  Everything turns on, but I can barely hear anything come out of the speakers even after I adjust the converter.  I think it's got something to do with the ground for the amps, but I'm not sure.  If anyone could help, I would appreciate it.
Posted By: bberman1
Date Posted: June 27, 2002 at 10:22 PM
Check the wiring on the hi to low converter. Are you using the factory Amp?
Posted By: Velocity Motors
Date Posted: June 27, 2002 at 11:44 PM
bberman1 is right, make sure that you are taking the signal after the amp for the converter, not after the deck in the dash.
Posted By: ott7283
Date Posted: June 27, 2002 at 11:59 PM
I'm trying to use the factory amps. I'm using a High Power Line Output converter and it says to install it after the deck.  In fact, it has a wiring harness that plugs right in the factory wiring harness.  The connections seem to be OK.
