Amp Turn on wire.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15753
Printed Date: March 29, 2026 at 1:49 PM
Topic: Amp Turn on wire.
Posted By: YoungKilluminat
Subject: Amp Turn on wire.
Date Posted: July 01, 2003 at 9:03 PM
for the amp turn on wire, what's the volt constant for that? Like is it 12v?
Posted By: esmith69
Date Posted: July 01, 2003 at 9:06 PM
it's supposed to be around +12V, but sometimes it will be as low as 10.5-11V;  also, if the car is running and the turn-on is hooked up to a wire in the ignition harness, 13-14V is not all that uncommon.
Ethan
Donate to the12volt.com
