alpine’s time correction
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15776
Printed Date: March 30, 2026 at 3:43 AM
Topic: alpine’s time correction
Posted By: Kadetheus
Subject: alpine’s time correction
Date Posted: July 02, 2003 at 7:41 AM
i recently bought an alpine cda-9813 hu and i get everything just fine but the time correction. maybe because i haven't had enough time to quite understand it. but i have a ford contour and i was wondering if anyone just off the top of their head had a clue as to what my time correction should be set to for the FL,FR,RL, and RR speakers.
thanks
Posted By: Manokat
Date Posted: July 02, 2003 at 9:44 AM
Previously posted by Kadetheus:
__________________________________________________________
I have the same HU.
Differences in speaker placement in the car create shift in sound image.  Time correction tries to balance the time it takes for the sound to come to the listener by delaying the audio signal to the listener. To set these settings for your unit you need to measure the distance of the farthest speaker to your head and the rest of the speakers. I take my Mazda Protege5 as an example.
My farthest speaker (from the speaker to my head) is the FR which is 2.25m.
My Front Left speaker to my head is measured 1.75M.
My Rear Left speaker to my head is about 1.25M
My Rear Right speaker to my head is about 2M.
So my settings for time correction are:
FR = 0
FL = (2.25 -1.75) / 343 x 1000 = 1.457 rounded up to  1.5
RL = ( 2.25. - 1.25 ) /343 x 1000 = 2.915 rounded down to 2.9
RR = ( 2.2.5 - 2.00 ) /343 x 1000 = 0.729 rounded down to  0.7
Hope this example helps.
Date Posted: July 02, 2003 at 10:52 AM
it helped a lot. but i still have one more question. when doing the distance thing, do measure as if the seat was not there or do you add a little to make up for the seat? i ask that because i have 4 door speakers
Posted By: ezridr
Date Posted: July 02, 2003 at 8:41 PM
Alpine also has available their own tape measure that has all of the time correction settings printed out on it and all you have to do is measure the distance and look at the time correction # and preset it into your HU
My mechanic told me, "I couldn't fix your brakes, so I made your horn louder"
Posted By: Manokat
Date Posted: July 03, 2003 at 7:46 AM
Theoratically, you should take it into consideration and you should find the shortest distance possible, mind you there are many possibilities sound  coming from a Rear Right speaker mounted on the door, bounching many places and eventualy arriving in your ears.
IMO however, you do not have to do that just measure the distance as if the seats were not there.
Morever the 343 m/s is the sound speed at 20 C only, The sound speed will vary depending on the temperature at which it travels.
That is why a tape measure will be of little use to set the time correction settings in Alpine HU.
Now if you had the Alpine 9815, you could preset and record these time correction settings to 6 preset buttons. That way you could set time correction according to different seasons. The  9813 does not have this feature.
Date Posted: July 03, 2003 at 5:01 PM
thanks dudes. what the speed of sound at about 95 degrees?
Posted By: Manokat
Date Posted: July 04, 2003 at 6:31 AM
First  convert Fahrenheit to Celcius:
C = (F-32) * 5 / 9   = (95-32) * 5 / 9 = 35 º C
Once the temperature in Celcius is known we can find sound speed/velocity with this formula:
V = 331.5 + (0.6 T)
Where:  V = velocity (m/s) and  T = air temperature (°C).
Thus, sound velocity at 95 °F or 35°C is:
V = 331.5 + (0.6 * 35 ) = 352.5
Hope this helps.
Posted By: dickytim
Date Posted: July 14, 2003 at 7:51 PM
may i hummbly suggest a pxa-h600, it worked for me, all the time correction and frequency range setting confused the hell out of me
Posted By: vudunoid
Date Posted: July 14, 2003 at 8:24 PM
Just a FYI on Alpines web site there is a i-Personalize link that will allow you to select your head unit and input the distance from each speaker to your selected listening point and it will give you all the time correction settings to input into you head unit. I hope this helps a bit more.
Posted By: stockcivic
Date Posted: July 15, 2003 at 9:48 AM
hmm I have never seen anything about time on my hu, probably doesn't have it but does anybody know about the sony Xplod CDX-MP450X, it is an older mp3 hu and it would be cool if I could make it sound a little better.
