Quesiton about ohms and subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15909
Printed Date: April 02, 2026 at 8:25 AM
Topic: Quesiton about ohms and subs
Posted By: TheMadScientist
Subject: Quesiton about ohms and subs
Date Posted: July 05, 2003 at 8:46 PM
Which is better a Kicker Solo-BAric L7 12" Dual 2 Ohm or a Kicker Solo-Baric L7 12" Dual 4 ohm?
Posted By: Sebastian018
Date Posted: July 05, 2003 at 9:00 PM
Ohms is basically the resistance that a speaker places on your amplifier. The less the resistance the more the amp will push.
Posted By: esmith69
Date Posted: July 05, 2003 at 9:12 PM
Neither one is necessarily "better" or "worse".  Each version is better suited for particular setups.  I'd say in most situations, the dual 2-ohm version is a little more versatile just because there are so many more amps out there that can run a single 4-ohm load, than there are amps than can run a single 2 or 1 ohm load.
The dual 2-ohm version can be wired up as a single 1-ohm load (voice coils in parallel) or a single 4-ohm load (voice coils in series).  Not many amps can do a 1-ohm load, but most 2-channel amps can be bridged to a 4-ohm load to maximize their power output.
The dual 4-ohm version can be wired up as a single 2-ohm load (voice coils in parallel) or a single 8-ohm load (voice coils in series).  Two 4-ohm DVC subs together though can be hooked up for a single 4-ohm load, for using with a 2-channel amp's bridged outputs.  So if you have a 2-channel amp and two L7s you'd probably want to get the 4-ohm DVC version.   If you intend to have just one L7 though, you might be better off getting the dual 2-ohm version.
Ethan
Donate to the12volt.com
Date Posted: July 05, 2003 at 9:13 PM
Thanks for the help guys.
