bazooka amp and subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16104
Printed Date: April 15, 2026 at 1:02 AM
Topic: bazooka amp and subs
Posted By: ramsfan
Subject: bazooka amp and subs
Date Posted: July 09, 2003 at 6:03 PM
I recently bought 2 10" bazooka el1004 subs which are 200w rms and a bazooka ela100.2 500 watt amp.Whould this amp give me enough power with these subs and what is the max i can get out of these subs.What is the best wiring from the amp to the subs to give me the most out of it.
Posted By: Sebastian018
Date Posted: July 09, 2003 at 8:04 PM
Your Subs are rated 200W RMS and the amp is only going to give you 115 x 2 @ 4 ohm . Only 115 per sub , YOu are going to get power.. Always try to get an amplifier with the same amount of RMS (subs) I Would Put a 8 Gauge would be fine, But If you are planning to get another bigger amp, Buy 4 Gauge...
Posted By: esmith69
Date Posted: July 09, 2003 at 8:28 PM
What kind of box are they going into (i.e. sealed, ported/vented, bandpass, etc.)?  That amp will work just fine if you don't plan to listen to it super super loud.  That's really what it all comes down to.  I used to have 2 10" subs in a bandpass box, getting 100 watts each and it was definitely loud enough for me.  But that's just me and my tastes, and I don't know if you're the type that wants it loud enough to hurt your ears, or just loud enough to thump real good...
Anyways, from your post it sounds like you are going for something that's as loud as possible, and in that case I'd suggest you at least start out with the equipment you've already purchased and listen carefully to it.  If it goes loud enough for your tastes then there's no need to get another amp.  If you find yourself wanting it so loud that it starts distorting, then you know you'll need a bigger amplifier if you want to have it that loud.  Distortion is not something you want to have happen on a regular basis as it can eventually lead to damaged components.
Ethan
Donate to the12volt.com
Posted By: ramsfan
Date Posted: July 09, 2003 at 9:28 PM
Thanx for your responces.The box is going to be made custom for a ford f150 supercrew so it will be inside the cab .When i get the box i will see how it sounds.
