sub popping noise problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16198
Printed Date: April 10, 2026 at 3:15 AM
Topic: sub popping noise problem
Posted By: yamez
Subject: sub popping noise problem
Date Posted: July 11, 2003 at 9:44 PM
I've been having popping sounds since I installed my old Solo-Baric in my Buick with the Fosgate Punch 250a2.
It makes a sound like an irregular heartbeat, with varying regularity and volume. It makes noise whether the car is on or off, but only when the stereo is on.
Here's the clincher: and it only makes the noises when I'm running the CD player in the Premier deck. No problems with radio, no problems with changer... only problems with the in-dash CD player.
Any ideas?
Posted By: esmith69
Date Posted: July 11, 2003 at 9:47 PM
what happens if you pause the CD does it still have the noise?  Also, what about when you first insert a disc and during the 5 or so seconds it takes to recognize and start spinning it up....do you hear the noise then as well?
Ethan
Donate to the12volt.com
Posted By: yamez
Date Posted: July 11, 2003 at 10:01 PM
Any time it's on "CD" it makes the noise, regardless of whether the CD is loading, playing, or paused. It is also the same regardless of whether the volume is at zero or turned up.
One more tidbit - usually it sounds like a heartbeat, but sometimes it sounds more like someone blowing into a microphone.
Posted By: SOUND PRESSURE
Date Posted: July 12, 2003 at 1:46 AM
Check your ground for your amp. Make sure that it is paint, rust free. Check your gains to make sure that they are not maxed out if so try lowring them to see if that helps. Overall check the grounds.
Sound Pressure
Posted By: yamez
Date Posted: July 12, 2003 at 12:33 PM
The gains don't change anything. The ground is well connected to the side of the trunk - I can't tell if it's metal or some sort of fiberglass material. Could that be the problem?
Posted By: bberman1
Date Posted: July 12, 2003 at 12:42 PM
Yes it must be pure clean metal. If you’re unsure of the material I would suggest that you find another ground location. But did the setup work fine on cd prior to you installing the Solo-Baric?  If it works fine when just playing the radio sounds to me like you might have a problem with the CD player itself?
Date Posted: July 12, 2003 at 11:16 PM
Change your ground to the floor of the trunk and scrape all paint until you see a shinny metal surface so that you know that it is a solid ground. Let us know if this resolves that problem.
Sound Pressure
Posted By: yamez
Date Posted: July 13, 2003 at 4:44 PM
Yeah, I sanded all the paint off where I connected it to the trunk floor. No change. I think that it might be worse when the car is running as well - possibly interfering some when the radio is on. Hard to tell.
I put the deck in at the same time as the sub, so I can't isolate it that way. However, it was all in another car immediately before that with no problem.
Date Posted: July 13, 2003 at 11:36 PM
How and where is your radio grounded at? Is it on a solid ground behind the radio? Do you have any other equipment in the car like external cross overs, eq's things like that? If so did you check the grounds on those? What kind of car do you have? Make,model,year.
Sound Pressure
Posted By: yamez
Date Posted: July 15, 2003 at 7:12 AM
93 Buick Century.
No other equipment. Premier deck going to the Fosgate amp to the Solo-Baric. Haven't finished the kick panels yet, so no second amp and no components.
The ground for the head unit looks great. Didn't have the time to move it just to make sure that wasn't it, but I can.
I did change the RCA cables and it made a huge difference. NOW, it is absolutely crystal silent except for when the in-dash CD player is spinning up or seeking to a different track.
Is there any conclusion other than that my deck is somehow fried? Could it still be the H/U GND?
The only other thing that I can think of is that the H/U isn't connected in a rock solid way to the dash kit. The one they sold me didn't have the right parts and I was impatient and jury-rigged a set-up with those little plastic ties. From the front it looks normal, but it's not in there in a perfectly stable way.
Posted By: natedogg84
Date Posted: July 16, 2003 at 2:23 AM
hey man i got the same problem.And i havent got a clue about what it is but wen i find out i will get back to you k
Posted By: bberman1
Date Posted: July 16, 2003 at 11:55 AM
Where are you getting the remote turn on lead from and do you hear any noise through the mids and highs? Also try and change the grounding source for the head unit
Posted By: yamez
Date Posted: July 30, 2003 at 9:18 PM
Magic! I replaced the RCA cables and that seems to have done the trick. I haven't done a thorough test yet, but it isn't noticable and annoying like it was before. Thanks for all the help!!!
