box volume
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16202
Printed Date: April 09, 2026 at 11:35 PM
Topic: box volume
Posted By: xTimx
Subject: box volume
Date Posted: July 11, 2003 at 10:55 PM
hey everyone,
this has been troubling me..
i have two 12" sony xplod subs, (the very first ones) and they're minimum volume box for each is 1.0 cu3, so i built a 2.0cu3 sealed box, they sound fine, but i am selling them and maybe the box too. now i am getting 2 12" MA audio subs (the xe series) and wanting to make another box but this time ported, BUT, each sub is required a minimum of 2.0 cu3 which is big, considering the size of my trunk, and it'll weigh down my back end too, i don't want to make a huge ass box that seals off the two subs and make each chamber 2.0 cu3, that is too much...how can i make a box that will sound good, and that is small..and if you can give me the cu3 for it...
xTimx
Posted By: tdsteele
Date Posted: July 12, 2003 at 8:57 AM
Why not just go sealed again so you can have the small box you want?? If the manufacturer calls for 2.0 on a ported then i wouldn't go smaller.
Posted By: xTimx
Date Posted: July 12, 2003 at 10:10 AM
yes but if i am gonna be making a ported box, then 2.0 cu3 is not gonna be suffice, or would it? if i make a box i want the subs to work well, sound good and not damage in the long run...lack of air space will damage the speaker..
Posted By: bberman1
Date Posted: July 12, 2003 at 10:27 AM
You could look into an isobaric setup https://www.maximacar.com/isobaric.htm
