2003 Honda Civic Preamp Outputs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16569
Printed Date: March 18, 2026 at 12:15 AM
Topic: 2003 Honda Civic Preamp Outputs
Posted By: Infidel
Subject: 2003 Honda Civic Preamp Outputs
Date Posted: July 22, 2003 at 11:36 AM
Hi there.
Thanks in advance for the assistance.
Does the CD player contained in the 2003 Honda Civic EX have preamp outputs and remote leads for the installation of an aftermarket amplifier?
I don't want to rip apart my dash to find out.
Regards,
Ed
Posted By: esmith69
Date Posted: July 22, 2003 at 12:04 PM
Are you referring to the separate factory cd player?  Or did the car come with a cd player/radio combo unit?
Either way there's no preamp outputs already in the vehicle.  You'll have to use a 4-channel line output converter if you're installing a 4-channel aftermarket amplifier, or a 2-channel line output converter if it's just a sub amp.
The aftermarket amp's remote turn on connection can be made by just tapping in to the +12v switched wire in the radio's harness.  Here's the wiring info I have for the 03 civic--as always, verify these wires with a DMM first before making connections to them.
BATTERYWHITE+IGNITION SWITCH HARNESS
GROUNDBLACK-RADIO HARNESS
ACCESSORY 01YELLOW+IGNITION SWITCH HARNESS
ILLUMINATIONRED / BLACK+RADIO HARNESS
DIMMERRED+RADIO HARNESS
FRONT LEFT SPEAKERBLUE+
FRONT LEFT SPEAKERGRAY/BLACK-
FRONT RIGHT SPEAKERRED / GREEN+
FRONT RIGHT SPEAKERBROWN / BLACK-
REAR LEFT SPEAKERBLUE / YELLOW+
REAR LEFT SPEAKERGRAY/WHITE-
REAR RIGHT SPEAKERRED / YELLOW+
REAR RIGHT SPEAKERBROWN / WHITE
Ethan
Donate to the12volt.com
Posted By: Infidel
Date Posted: July 22, 2003 at 12:09 PM
Just the cd player/radio combo unit that comes standard with the EX.
Posted By: esmith69
Date Posted: July 22, 2003 at 12:11 PM
yea right after I posted my first reply I realized it didn't really matter what type of system it was.  It's not gonna have preouts regardless.  so i updated my post with some more info
Ethan
Posted By: Infidel
Date Posted: July 22, 2003 at 12:18 PM
Thanks ethan. I think it's time to purchase a new head unit. I don't like the converters... Unless they've signifigantly improved since I was into this hobby (about 5 years ago).... the sound quality suffered.
Would be nice if I could find a head unit that completely enveloped the slot taken up by the stock head unit... I don't remember if it is the standard size or if I would have to use one of those ugly and cumbersome brackets..
Posted By: esmith69
Date Posted: July 22, 2003 at 10:29 PM
Actually you'd be surprised at how good aftermarket units look when used with this dash kit.  You can hardly even tell the difference.
Ethan
