stereo cutting out
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16604
Printed Date: March 18, 2026 at 5:37 PM
Topic: stereo cutting out
Posted By: Alex Burrell
Subject: stereo cutting out
Date Posted: July 23, 2003 at 4:56 AM
Dear sirs
Can you please help me! My stereo cuts out when I turn it up to a high volume, the facia will begin to flicker then it turns itself off. I have two amps running, 1x kicker and 1x alpine v12, all in all probably about 500 watts RMS. My alternator is 55amp I think, so if I uprated it to 90 amp would this eliminate this problem that I'm having? Or if not how about a power cap?  The alpine amp runs my sub and it's protector light flashes red when I turn the volume up, does this mean the amp is screwed or is it just that the battery is struggling? Please can you give me some advice
Many Thanks in advance
Alex Burrell
Posted By: esmith69
Date Posted: July 23, 2003 at 6:59 AM
The protection light could mean either it's not getting enough voltage (charging system problem) or there's a speaker short.  But as for the head unit, when does it turn itself back on?  do you have to wait a few minutes for it to cool down?  or will it go right back on immediately as long as you turn the ignition off and then on again?
Ethan
Donate to the12volt.com
Posted By: sonicsound
Date Posted: July 23, 2003 at 9:49 PM
My guess would be the ground for your deck.  I just finished on a car with the same problem at Circuit City. Check the ground and make sure the paint is scratched off and its not grounded to a small piece of metal.  If it is run a ground wire to the car's actual chassis.  Hope that helps....
Sonic
Pioneer AVH-P4000DVD
Zapco 360.4
Zapco 500.1
Zapco SP-4SL Processor
Two JL 10 W3v3d2
Alumapro 15 Farad Cap
