kicker impulse 2000 fuse problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16673
Printed Date: March 20, 2026 at 8:09 AM
Topic: kicker impulse 2000 fuse problem
Posted By: profuse007
Subject: kicker impulse 2000 fuse problem
Date Posted: July 24, 2003 at 5:38 PM
my friend who has kicker impulse 2000, his fuse kept blowin out everytime. whats the problem?
Posted By: bfog99
Date Posted: July 24, 2003 at 6:02 PM
 My brother-in-law had a problem with that with his Rockford Fosgate amp. His problem ended up being a short in the power wire to the amp. Just something to think about.
Posted By: bberman1
Date Posted: July 24, 2003 at 6:24 PM
Need some more info. Dose it happen when ever he attaches the power cable or fuse? Or dose it blow the fuse when you play tunes? Also what fuse is it the one at the battery or the one on the amp, and has it ever worked correctly?
Date Posted: July 24, 2003 at 9:56 PM
plug in power wires, it blew out. then replace fuse, sparks and blown into pieces.
Houston,TX
Posted By: bberman1
Date Posted: July 25, 2003 at 2:14 PM
Could be many things but here are a few to start with
1) The insulation on one of the + power wires is torn, cracked or punctured and is coming in contact with a ground (any metal surface)
2) The power wires on you amp are reversed, Make sure you are connecting the + to the +terminal and the - to the - terminal.
3) At the terminal on the amp strands of the power or remote wire are coming in contact with the amp or a ground source
4) The amp has an internal short.
Did the setup ever work correctly?
Date Posted: July 29, 2003 at 9:51 PM
i believe i worked long time ago, but hes just switchin with his existing amp and this happen.
Houston,TX
Posted By: bberman1
Date Posted: July 29, 2003 at 10:18 PM
I don’t understand. He had an old amp that worked fine he got a new or used one and it blows the fuse? Am I correct?
