Nissan Altima Radio Problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16747
Printed Date: March 22, 2026 at 9:26 AM
Topic: Nissan Altima Radio Problems
Posted By: rick655
Subject: Nissan Altima Radio Problems
Date Posted: July 27, 2003 at 7:18 AM
I have been having probleems with my daughters' Altima OEM HU (Clarion CD/Cass/Tuner). It would work (for a while) only if I pulled it out and unplugged/replugged everything.
I bought a new HU with wiring and antenna adapters, and installed that. Everything worked(power on, equalizer,memory,etc) except I got no sound. I pulled out both amps in the rear deck to inspect them. When I ground the amp for the rear speakers (reinstall it in its holder), the rear speakers come on. Then, when I ground the front amp, everything dies (grounding it gives a pretty good spark). If I unground the front amp, the rears come back on.
Do I have a short in the front speaker wiring? I swapped amps, just to see if the problem was with them, but I get exactly the same result.
Posted By: -oz-
Date Posted: July 28, 2003 at 8:59 AM
How large is your power supply wire? If it is a factory 18 gauge feed then it is probably not large enough to supply your system.
