| Print Page | Close Window |
Engine Noise?Printed From: the12volt.comForum Name: Car Audio Forum Discription: Car Stereos, Amplifiers, Crossovers, Processors, Speakers, Subwoofers, etc. URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16779 Printed Date: March 23, 2026 at 6:08 AM Topic: Engine Noise? Posted By: sonicsound Subject: Engine Noise? Date Posted: July 28, 2003 at 10:02 AM What's up guys, I need some help. I have a four channel amp for my interiors and a mono amp for my subs. My four channel is getting a ton of feedback or engine noise. Not really static but more of a hiss and when I start the car there is even more. Now I know it could be my RCA's because they are pretty close to my power lines in the car, I'll be moving those today. But I was wondering if you have anyother ideas. My subs have no feedback what so ever. Any suggestions please post back. Thanks in advance. ------------- Sonic Pioneer AVH-P4000DVD Zapco 360.4 Zapco 500.1 Zapco SP-4SL Processor Two JL 10 W3v3d2 Alumapro 15 Farad Cap Replies: Posted By: bberman1 Date Posted: July 28, 2003 at 10:11 AM You need to run you power cables (including the remote wire) on one side of the car and your signal cables on the other side. By moving the cables to separate sides should take care of the alternator wine. If you still have a problem you could have a ground loop. But move them and let us know what happens Posted By: sonicsound Date Posted: July 28, 2003 at 10:24 AM Ok, well I already have the power cables run seperately I already have that down. I work at Circuit City and we always put the remote wire with the RCA's and that has never created a problem. So I'm guessing the RCA's are too close to the actual car power wires or I have something wrong
------------- Sonic Pioneer AVH-P4000DVD Zapco 360.4 Zapco 500.1 Zapco SP-4SL Processor Two JL 10 W3v3d2 Alumapro 15 Farad Cap Posted By: bberman1 Date Posted: July 28, 2003 at 10:30 AM The remote wire can cause EMI interference I have seen it many times. How do you have it grounded? And do you get engine noise in all 4 speakers?
Posted By: sonicsound Date Posted: July 28, 2003 at 10:48 AM grounded to the chasis, seperately from the ground of the sub amp and I do get engine noise in a ll four speakers
------------- Sonic Pioneer AVH-P4000DVD Zapco 360.4 Zapco 500.1 Zapco SP-4SL Processor Two JL 10 W3v3d2 Alumapro 15 Farad Cap Posted By: bberman1 Date Posted: July 28, 2003 at 11:11 AM Noise Elimination Checklist (courtesy of Velocity Motors)
The following checklist can be used for the basic troubleshooting of noise in mobile audio installations. The key to success is to relax and systematically go through the vehicle. The problem WILL be found. Murphy’s Law states, however, it will be in the last place you look. 1. TO BEGIN: Be sure that system is correctly designed and matched for compatibility. 2. INSPECT VEHICLE: Verify ground from negative battery terminal to fender and/or chassis. Upgrade as needed. This connection must be capable of handling the current of the entire system. ASSUME NOTHING! 3. CHECK VEHICLE ELECTRICAL SYSTEM: Battery, alternator, etc. Make sure your alternator can adequately supply the sound system as well as other vehicle systems (alarm, lighting, etc.) AMPS/VOLTAGE NOT OK: See service technician to have system repaired or upgraded. 4. PROPERLY MOUNT COMPONENTS: 4.1 Isolate from chassis. 4.2 Mount away from vehicle harnesses, computers, etc. 4.3 Do not hesitate to use a factory wiring diagram if needed. DO NOT GUESS! 5. PROPERLY RUN ALL CABLES: 5.1 USE CORRECT GAUGE WIRE. 5.2 Ground all components to a central point or use "ground sniffer" to locate a quiet area. 5.3 Run power and signal cables down opposite sides of vehicle. 5.4 Properly terminate all connections (double check!). 5.5 Use a relay for clean power if needed. 5.6 Use the same gauge wire for power and ground. 5.7 Check signal cables for continuity and repair any open shields or cold solder points. 6. HOOK EVERYTHING UP: Follow the instructions provided with the component and be sure of polarity. Make sure everything is working and set all line levels. If noise exists, please continue... GENERAL PROCEDURE FOR LEVEL SETTING: When setting gain levels, always work from the source unit to the amplifiers. Start by checking your L-R balance. Use a CD with test tones (example: 1kHz sine wave). Alternate method: Use a pink noise track and a real time analyzer set to read dB level. Convert the dB reading to RMS volts using the conversion chart at the end of this checklist. Connect a Digital Volt Meter (DVM) to each of the RCA outputs of the head unit (set DVM to AC VOLTS). The output voltage should be the same on both channels. If your meter reads peak voltage, multiply the meter reading by .707 to get the RMS voltage. If the next component is a Line preamp, set the gain controls on the preamp to the maximum voltage required for the inputs of the next component in the signal path (or until just before distortion is heard) and measure the signal with the DVM. Remember…some preamp/line drivers are capable of over 10VRMS output! Measure and match the output of each component to the maximum recommended input level of the component following it down the signal path to the amplifier(s). Keep the input level controls (gains) on the amplifiers as low as possible. 7. IGNITION NOISE: Check for noise in each of the following switch positions: 7.1 IGNITION ON, CAR NOT RUNNING: It is possibly related to an Electronic control module, digital dash, or possibly fuel pump. Do not attempt to filter an E.C.M.! Re-route cables away from control unit or fabricate a shield. 7.2 ACCESSORY POSITION, CAR NOT RUNNING (All accessories off): Substitute an isolated signal source (such as a walk-man CD, tape player, or home CD player), if the system plays fine, the head unit needs to be checked. 7.3 ENGINE RUNNING: Make certain no ground loops exist between components (if they do, see next section.). NOTE: Pulse Width Modulated headlight switches (like some Honds cars use) can cause a whining type of noise when on, verify this type of problem by turning lights on and off while listening for noise. If this is the problem, the headlight switch may need to be replaced with an alternate type. 8. GROUND LOOPS AND/OR RADIATED NOISE EXIST: Check resistance of all ground cables; consider using central point grounding. Resistance needs to be as low as possible (around .2 ohms) on your meters lowest scale. If not, re-do or upgrade cables. If it is not possible to get the resistance’s this low, try to get them all at an equal value (all the same resistance.) TIP: Use the combination of a DVM and a ground sniffer (plans available from our technical dept.) to find the best ground point. Remove the positive cable from the vehicles’ battery and check resistance’s from: A. Ground point of all units with connection point on chassis. B. Connection point on chassis with the negative terminal of the systems battery. C. Battery negative terminal with the chassis connection point. 8.1 RADIATED NOISE: Place head unit next to amplifier and plug directly in (or use an isolated source such as a Discman or Walkman) and turn system on. Listen for noise. If noise is gone, please continue... Muting plugs can be used to systematically troubleshoot the point at which the noise is entering the system. Muting plugs consist of a male RCA end with the positive and negative (tip and shield) connected together (a dead short). Open RCA ends can become an antenna radiating noises into a sound system. By inserting muting plugs into the inputs of each component in your system one at a time the source of the noise can be found. This is a process of elimination starting with your amplifiers. Insert the muting plugs into the inputs of the amps. Turn on each amp (with the muting plugs inserted) one at a time and with the car running listen for noise. If none is heard, the amps are OK. If all amps are OK, connect the next piece in the signal path upstream of the amps (typically the crossover) by connecting its outputs to the amp inputs using normal RCA cords. Now insert the muting plugs into the inputs of that product and turn on the system. If noise is heard now, power the component with an external power supply. If the system is now quiet, the noise is probably entering through the components’ power supply. If no noise is heard, insert the next component upstream in the signal path and check it the same way. Keep working your way upstream all the way to the head unit. Once the problem is found, you can stop. 9. ANTENNA NOISE I: Unplug antenna from the back of the head unit and listen for noise. If noise is eliminated, see section 13. ANTENNA NOISE II. However, if noise remains: 9.1 With head unit powered up and all speakers connected, slowly pull head unit from dash cavity and check for noise: A. Noise Remains: Noise is entering on one of the power lines; ignition or memory. Install filter onto appropriate wire. B. No Noise: The dash harness is radiating noise. Locate and re-route harness and shield entire harness next to the head unit. Isolate head unit chassis from metal dashboard. 9.2 If noise still remains, determine which of the following noises is present and supress the noise at the source using the following sections: 10. IGNITION NOISE II 11. ACCESSORY NOISE 12. ALTERNATOR WHINE NOTE: The following checks will not be necessary in most cases, but if the previous checks are not effective, continue. 10. IGNITION NOISE II: Determine the source of the ignition noise. 10.1 ONE OR TWO CYLINDERS: Try the following fixes in order: A. Check for loose or defective plug wire. B. Check for cracked rubber boots at distributor or coil(s). C. Re-route plug wires away from car wiring or sensor leads traveling into passenger compartment. D. Check for bad plugs (excessive gap). E. Replace cap and rotor. 10.2 ALL CYLINDERS: Try the following fixes in order: A. Check ground from engine to firewall. Upgrade if needed. B. Install ground strap from hood to firewall. C. Check heater core ground. D. Check A.C. accumulator ground. E. Move all wiring away from high energy ignition (H.E.I.) and plug wires. F. Inspect H.E.I. ignitions, modules, and coils for the following and replace if needed: 1.Distributor cap; cracked, loose, or carbon buildup. 2. A rotor with burned black spot on wiper or pits in the surface. 3. Defective coil. 4. Oily film on lead terminals or inside of cap. 5. Defective ignition module (can cause ignition noise on FM only). 11. ACCESSORY NOISE: May be identified as a turn-on "pop", relay "pop", or other motor type noise. A. Turn-on "pop" is usually due to components turning on before transients have a chance to settle. Delay turn-on to suspected unit. B. Relay "pop" is due to a component ground being at the same potential as, say, the brake lights. Move component ground. Can also be due to excessively high gain settings. C. Filter the power line to the noisy motor (check motor current draw for correct filter.) 12. ALTERNATOR WHINE: 12.1 CHECK ALL GROUND CONNECTIONS. If an audio component has some type of internal ground switches or jumpers, try changing settings. 12.2 CHECK ALL GAIN SETTINGS. Some components have gain built into their circuitry (either fixed or variable) and will increase signal levels. Gain controls are for matching signal voltage levels… They are not volume controls. 12.3 Check continuity of all RCA shield connections. Look for open or cold soldered connections. 12.4 On products with Balanced Differential Inputs, make sure no metal barreled RCA plugs are touching each other. This will defeat the differential circuit and create noise. 12.5 Eliminate all ground loops. (Refer to section 8; GROUND LOOPS.) 12.6 Install a cable from alternator ground to battery negative terminal along side the alternator charge wire using same gauge wire as main system power wire. 12.7 Install filter on alternator output lead. 12.8 Have mechanic check alternator – repair or replace if necessary. 13. ANTENNA NOISE II: Fixed mast or power antennas go to section 13.2... 13.1 Windshield antennas: plug antenna back into radio and place aluminum foil over entire dash top and ground it with clip leads to door jamb switch. A. NO NOISE: Use noise sniffer to locate which part of the dash the noise is generating from. After locating problem area, the following fixes are possible: 1. Line underside of dash with aluminum tape and run a ground lead to it. 2. If a noisy cable can be found, move it or shield it and ground the shield. 3. As a last resort, install a conventional antenna. B. NOISE REMAINS: Measure resistance from antenna cable shield where it plugs into the head unit to a good ground using the lowest scale on DVM. Repair if necessary. Measure shield again. If ground is still bad, replace the antenna lead. 13.2 Fixed mast or power antennas: Measure antenna ground from shield at plug end to ground on back of head unit using the lowest scale on DVM. A. POOR GROUND: Disconnect and clean all RF connections. Check for a good ground at the antenna trim ring and mounting bracket. If the ground is poor, run a braided strap from the base of the antenna to a good ground. If noise remains, please continue... B. GOOD GROUND: Try using a test antenna. The base must be grounded. Also, hold the base, not the mast. 1. POWER ANTENNA TEST: Disconnect antenna connector. Measure the resistance from the mast to the center conductor pin of the lead-in. a. If resistance is less than 2 Ohms using the lowest scale on the DVM, measure from the mast to ground. If open (infinite resistance), suppress at the source. b. If resistance is more than 2 Ohms, replace the antenna. 2. FIXED MAST ANTENNA TEST: Replace antenna. 14. You’re Done! |
