Kicker L7 - 4 ohm or 2ohm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16870
Printed Date: March 24, 2026 at 3:52 AM
Topic: Kicker L7 - 4 ohm or 2ohm
Posted By: Alex100
Subject: Kicker L7 - 4 ohm or 2ohm
Date Posted: July 30, 2003 at 7:50 AM
Hi there,
I am new to this forum and new to the car audio world.
I am looking at buying a single Kicker 10" L7. I have an Alpine mrd-m500 mono amp to run it with. What i would like to know is whether to buy the 4 ohm or 2ohm version and how to wire it in order to get the best from my amp.
Cheers
Alex
Posted By: bberman1
Date Posted: July 30, 2003 at 11:06 AM
 The MRD-M500  puts out 500 watts RMS X1 @ 2 ohm, So You will want to buy the 4 ohm L7 and wire it in parallel to the amp https://www.audiobahninc.com/tech/wiring/parallel_parallel_dual_4.pdf
The above configuration will present the amp with a 2 ohm load and will provide you with optimal performance.
Posted By: sssssss27
Date Posted: July 30, 2003 at 11:17 AM
Don't use the equation on that web site though, for parallel to calculate the resistence it's 1/Rt = 1/R1 + 1/R2 etc. Other then that it's good.
Posted By: Special-K
Date Posted: July 30, 2003 at 11:42 AM
No, no, no. Get the 2 ohm. You can still wire it 2 ohm for this amp. But in the future u might want to run it 1 ohm. IF u get the 4 ohm u wont be able. The whole point of dual coils is for the many possibilites. You can wire that thing like 2-???? different ways, depending on the amp.
Date Posted: July 30, 2003 at 11:58 AM
How can you wire it up for 2 Ohm if has dual 2 Ohm voice coils?
Posted By: bberman1
Date Posted: July 30, 2003 at 1:18 PM
Special-K You cannot wire one Dual 2 ohm sub into 2 ohms. However you can wire (2) 2ohm dvc subs into a 2 ohm load
Date Posted: July 30, 2003 at 1:24 PM
That's what I was thinking, just making sure Ohm's law didn't change or something.
Posted By: Alex100
Date Posted: July 31, 2003 at 2:28 AM
Cheers guys
Posted By: bberman1
Date Posted: July 31, 2003 at 10:38 AM
posted_image
