2001 Civic LX Amp and Box install help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16882
Printed Date: March 24, 2026 at 10:26 AM
Topic: 2001 Civic LX Amp and Box install help
Posted By: phill_b
Subject: 2001 Civic LX Amp and Box install help
Date Posted: July 30, 2003 at 1:45 PM
Hi All
This is my first time posting here.  I cant believe I have never seen this resource before.
I have a 2001 Civic and want to hook up my amp and box to the factory stereo.  I know, I know.  I will be installing a aftermarket deck soon but a little straped for cash.
First thing.  Does the factory deck have a 12 volt ingnition or aux output so i can use for the amp's relay?  If it does not then i can always use a switch.
Second,  I need a line input into the amp.  I was thinking of using the rear speakers but am concerned about the powered output.  Any ideas as to how to hook up for line input for amp???
The head unit is just factory and want to keep it as close to factory for now untill i get the kit and harness and new deck.
Phill
Posted By: bberman1
Date Posted: July 30, 2003 at 2:20 PM
You have come to the right place, this is a pretty simple install and it sounds like you have a good idea of how to hook it up. For your remote wire you will want to tap into the radios Yellow/red switched + 12 volt. As far as a signal for the amp you will want to use a good quality high to low converter and tap into both rear speakers as you said. I would suggest you use a PAC SNI-35 https://go2pac.com/products/loc.htm
Below is the wiring diagram for your car
ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|BLACK/ red           |+  |ignition harness            |
| SECOND ACCESSORY|WHITE/ red           |+  |ignition harness            |
|       POWER LOCK|WHITE/ blue          |-  |gray plug above drivers kick|
|     POWER UNLOCK|WHITE/ green         |-  |gray plug above drivers kick|
|       LOCK MOTOR|yellow/black        |   |back of the fusebox *3      |
|     UNLOCK MOTOR|YELLOW /GREEN        |   |back of the fusebox *3      |
|    DISARM DEFEAT|yellow              |   |back of the fusebox *3      |
| PARKING LIGHTS +|RED / black           |   |back of the fusebox         |
| PARKING LIGHTS -|blue                |   |factory alarm plug *1       |
|       HEADLIGHTS|blue/red            |-  |headlight switch            |
|     DOOR TRIGGER|*2                  |-  |factory alarm plug *1       |
| DOME SUPERVISION|comes on with unlock|   |                            |
|  TRUNK/HATCH PIN|red                 |-  |factory alarm plug *1       |
|       TACHOMETER|blue                |   |test connector *4           |
|      SPEED SENSE|WHITE/ green         |   |PCM *5                      |
|       BRAKE WIRE|WHITE/ black         |+  |brake pedal switch          |
|     HORN TRIGGER|orange              |-  |steering column             |
|           WIPERS|blue (L), blu/yel(H)|-  |steering column             |
|  LF WINDOW UP/DN|RED / blk - RED / yel   |A  |drivers window switch       |
|  RF WINDOW UP/DN|blu/red - blu/wht   |A  |drivers kick panel          |
|  LR WINDOW UP/DN|brn/wht - brown     |A  |drivers kick panel          |
|  RR WINDOW UP/DN|blu/org - brn/yel   |A  |drivers kick panel          |
|        RADIO 12V|WHITE/ red           |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|yellow/red          |+  |radio                       |
| RADIO ILLUMINATE|RED / black           |+  |radio                       |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|grn/blk - lt green  |   |radio                       |
|       RF SPEAKER|grn/yel - gry/red   |   |radio                       |
|       LR SPEAKER|blu/wht - blu/blk   |   |radio                       |
|       RR SPEAKER|pink - blu/yel      |   |radio                       |
Notes:
NOTE:  This vehicle has an immobilizer system that needs to be bypassed when adding remote start.    *1 The factory alarm plug is a green plug above the drivers kick panel.  *2 The drivers door trigger is green, front passenger door trigger is lt. GREEN/ red, and the rear door trigger is GREEN / WHITE.  *3 In the top left plug.  *4 It is a 2 pin plug to the passenger side of the battery.  *5 The PCM is behind the glove box. The vss is in a connector A (31 pins), pin 18. The vss is also blue/white at the cruise control module to the left of the steering column.
