Audiobahn AW1206T
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16926
Printed Date: March 26, 2026 at 2:27 AM
Topic: Audiobahn AW1206T
Posted By: troysnx
Subject: Audiobahn AW1206T
Date Posted: July 31, 2003 at 11:35 AM
Hey there, I am planning on re-doing my whole system eventually, just as soon as I can get some dough.  Anywho I plan buying 2 -12" subs and putting them into a bandpass box.  I was looking at these Audiobahn's.  Now are these subs good quality, or are they just not worth the money.  And if these are worth my money what amp would a good run these.
I'm not looking for perfect presision, nor am I looking to break world records.  I want my car to be heard, and to shake me and my passanger, but I don't need something that can be heard 200 yards away.  I am also trying to save money.
R.Troy
Posted By: bberman1
Date Posted: July 31, 2003 at 11:49 AM
Those subs can not be put in a band pass enclosure. And to be honest I would not waste your money on the subs. I ran some 08 for about a year or so and had lots of problems with them. They look nice but they are not very reliable. But if you tell us what your budget for subs and amp is maybe we can make some suggestions.
Posted By: troysnx
Date Posted: July 31, 2003 at 11:55 AM
Well unfortunetly I am poor, and I'm looking to only spend a max of 500 for the subs, box, and amp.  Is my goal achievable with this little money?
Also I need one more opinion.  I will soon enough need to replace the 6.5's in my doors, I only want to spend maybe 150 there, so any suggestions?  (I usually shop ebay so I try to find myself some deals)
R.Troy
Posted By: bberman1
Date Posted: July 31, 2003 at 12:07 PM
I would suggest some comp VR's ($155 eBay) https://kicker.com/ShowPage.cfm?filename=compvrsub.html&menu=SUBWOOFERS and a JBL 1200.1 https://www.purecaraudio.com/product.asp?0=200&1=352&3=322 that leaves you about $50 for an enclosure.  With that amp you can get either the 4 or 2ohm model and wire it in parallel to the amp
4 ohm https://www.audiobahninc.com/tech/wiring/parallel_parallel_dual_4.pdf
2 ohm https://www.audiobahninc.com/tech/wiring/parallel_parallel_dual_2.pdf
Posted By: bberman1
Date Posted: July 31, 2003 at 12:13 PM
Also how many watts will you be running to those 6.5's
Posted By: troysnx
Date Posted: July 31, 2003 at 1:07 PM
I was planning on something small, like 80ish watts to each.  I don't want my subs to drowned out everything else, so is 80watts efficent, or do I need more/less?
R.Troy
Posted By: troysnx
Date Posted: July 31, 2003 at 1:10 PM
Sorry for the double post, I cannot figure out how to edit my old one.  But with the Comp VR's should I use a bandpass box or sealed or...
R.Troy
Posted By: bberman1
Date Posted: July 31, 2003 at 1:17 PM
When you say 80 watts are you talking about your subs or your 6.5's ?
Posted By: bberman1
Date Posted: July 31, 2003 at 1:18 PM
I would suggest a sealed enclosure
Posted By: troysnx
Date Posted: July 31, 2003 at 1:23 PM
I was talking about the 6.5's.  Is that way too much, or too less?  Keep in mind I am no speaker guiness, and I have no idea about wiring.  After I purchase all my accessories me and my dad are going to try to wire it all up.  If all else fails we'll head over to Curcuit City and get some help.
R.Troy
Posted By: bberman1
Date Posted: July 31, 2003 at 1:30 PM
You should be able to figure out how to install everything and if you have any ? we are here for you. But I would suggest some MB Quart RCE 216 https://www.mbquart.com/2003/en_US/products/prod_detail.asp?isArchive=&cat=auto&series=reference%20series&strt=1&model=RCE+216 they will give you some outstanding clarity as well as reliability. I would suggest that you give them close as  to 130 watts rms and they will even out nicely with the subs.
Posted By: troysnx
Date Posted: July 31, 2003 at 1:37 PM
I'm sure this sounds like a silly question, but should I go with Coaxial or Component, is it just prefrence, or do they make a big difference which one I use.  Remember I want to go cheap, and if coaxial only a slight difference I would like the cheaper ones.
R.Troy
Posted By: bberman1
Date Posted: July 31, 2003 at 1:45 PM
There used to be a big difference in sound, but now days I think it comes down to personal preference. But those RCE 216 are some nice speakers and can be found for around $180. You have to look at it as an investment if you have a good pair of speakers they will give you years and years of listening enjoyment. It ends up costing more in the long run if you keep buying speakers that you are not happy with then to just buy 1 good set.
Posted By: troysnx
Date Posted: July 31, 2003 at 1:50 PM
I appreciate all the help you've giving me.  I've took my notes, so now all I have to do is wait for the pay checks then I'll be on my way to a great sound system.  Thanks Again!
R.Troy
Posted By: bberman1
Date Posted: July 31, 2003 at 1:55 PM
Not a problem, and remember if you have any questions don’t hesitate to ask>
