Schematics For Amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17266
Printed Date: April 03, 2026 at 7:00 PM
Topic: Schematics For Amp
Posted By: Th3 Gr33k
Subject: Schematics For Amp
Date Posted: August 07, 2003 at 1:22 AM
Does anyone know where I can receive a schematics sheet for a Road Gear Amp? The Model No. is RGMF250. It has 12Volts Negative Ground and supports 2,4,or 8 OHM speakers. If so please respond. Thank you.
Posted By: wvsquirrel
Date Posted: August 07, 2003 at 1:39 AM
Schematics sheet? Are you wanting a parts breakdown/electrical schematic or the available wireing diagrams and/or system configurations? ------------- Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Date Posted: August 07, 2003 at 1:43 AM
A sheet of the parts breakdown/electrical schematic. Because I fried the AMP and I need to replace them.
Posted By: hobbes6981
Date Posted: August 07, 2003 at 10:22 AM
You would be MUCH better off just chucking that amp and purchasing a more repudable brand. Unfortunately I've owned a Road Gear amp (...shiver..), and I fried it easily. Post your setup and maybe some of the pro's in here can help you out on a viable amp choice.
Posted By: bbmecp
Date Posted: August 09, 2003 at 12:16 AM
i do amp reapir for a shop on the side what parts did you fry. the power supply side or the channel side. what is the amp doing. no output? drawing excessive current ? dc to the speakers i can probably tell you where to look for parts like mosfets and other parts if i dont have them already.
------------- everyone calls me subwoofer
Date Posted: August 09, 2003 at 12:34 AM
Well what happened is I took a plug and tried to wire it up to hook into an outlet, stupid me I was wated at the time, and I thought there might have been some type of voltage regulator on it to conver 120V to 12V. So... anyway I plugged it in and it fried the damn thing. So im guessing I fried the power supply side of the amp.
Posted By: bbmecp
Date Posted: August 13, 2003 at 12:26 AM
Well that is one problem i have never faced. If nothing was hooked up as far as speakers go then you probably just fried the power supply side. How bad is another thing. Open the amp up and look for damage such as burnt traces on the main board and when mosfets decide to really blow the usually crack and or shatter. there is a number on them they are the black squares that hang of the sides of the board. the ones closest to the big coil. big magnet with copper wrapped all around it is the powe supply side. If you are lucky that is all that is wrong and those mosfets cost anywhere from .02 c all the way up to like 10 bucks a piece. just do a web search and find the cheapest ones and rplace them since the only way to test them is with a scope.
Date Posted: August 19, 2003 at 10:43 AM
Thanks for the advice I will look into it. I also havent replied in a while cause of my POS computer only has dial-up and it was infected with a virus. I have a guy that I work with that used to be a engineer for NASA and he is a human schematic. Thank you for all of your help.
Posted By: JamesRH
Date Posted: August 19, 2003 at 10:48 AM
*note to self...dont plug car audio into 120 volt AC outlet*
