JL subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17479
Printed Date: April 09, 2026 at 4:40 AM
Topic: JL subs
Posted By: mj239air
Subject: JL subs
Date Posted: August 12, 2003 at 8:52 AM
Hey there you all just another question for you. I am installing 2 JL 18w6's and was wondering of any way to convert the speaker wire connections over to a spring loaded speaker terminal. I have an old set of 8" solobaracs that have this type of connector and just think it would be more suitable for the 18's. I am using 8 guage wire for the speaker wire and just don't think soldering it will do the trick. If anyone has any ideas they would be greatly appreciated.
Posted By: bberman1
Date Posted: August 12, 2003 at 12:56 PM
I don’t know about converting it to a spring loaded terminal but soldering the cable to the sub will give you the best connection.
Posted By: donkason
Date Posted: August 12, 2003 at 2:59 PM
I agree that JL's terminals SUCK. That is the only bad part about them. I have never seen a solution either.
