Eclipse aluminum or titanium with RF amps?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17870
Printed Date: April 17, 2026 at 6:03 AM
Topic: Eclipse aluminum or titanium with RF amps?
Posted By: pureRF
Subject: Eclipse aluminum or titanium with RF amps?
Date Posted: August 20, 2003 at 7:24 PM
Im getting one sub and listen to rap. ( i had 2 RF 15's with a 1001bd but dont want to get a new alternator so im switching it all) but neways is the 12'' titanium really worth it if im going to have one sub? How would i wire 2 351M's (rockford fosgate)amps to one sub so the amps get a 2 ohm load? or would i have to run just one amp? And what would u guys suggest running if i dont want to much power? would a good amp that runs 500 watts work like the 501bd?
thanks
dream it, build it, fiberglass it
Posted By: pureRF
Date Posted: August 20, 2003 at 7:26 PM
disregard the 2 351M's. woudl the 501bd work? or would i have to get somthing more powerful? ( i would have a 1 farad cap)
thanks
Posted By: wvsquirrel
Date Posted: August 21, 2003 at 2:00 AM
Eclipse Titanium SW9122
12" sub
4ohm DVC
750 RMS
1500 Peak
Eclipse Aluminum SW8122DVC
12" sub
4ohm DVC
500 RMS
1000 Peak
Rockford Fosgate Power 501bd
500 x 1 @ 2ohms (based on 14.4 volts)
300 x 1 @ 4ohms (based on 14.4 volts)
Rockford Fosgate Power 500bd
600 x 1 @ 2ohms (based on 14.4 volts)
Going by the specs, the Eclipse Aluminum SW8122DVC and either RF amp I listed would be a great match at a 2ohm load. Keep in mind that RF bases specs on 14.4 volts, so you may want to consider the 500bd instead of the 501bd. I ran a 500bd for about a year and had absolutely no problems with it (other then my HE's at the time kept blowing!)
Since you don't want to upgrade your alt, and are looking to keep things simple, then why spend the money on the Titanium line if you don't plan on getting an amp and alt that can properly push one. Just MO. ------------- Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Posted By: pureRF
Date Posted: August 21, 2003 at 3:39 PM
Well i want the best bass I can get without going to high on amps so i dont mess up the electrical system or have a get a new alternator and all that crap. Will one aluminum 12 hit in a sealed enclosure? i listen to rap.
thanks
Posted By: tdsteele
Date Posted: August 21, 2003 at 6:36 PM
From what i have heard on those eclipses, they will pound your head and sound good. bberman is the one to ask, he runs the titaniums.
Posted By: pureRF
Date Posted: August 21, 2003 at 8:38 PM
alright thanks
Posted By: pureRF
Date Posted: August 21, 2003 at 8:39 PM
i think im gonna try to get one of those new kicker amps and run the SX650.1 to one of them (that will be 650 watts) Will that work fine ne suggestions.
Date Posted: August 22, 2003 at 12:54 AM
Should be fine. You might also want to consider the JBL BP600.1 if you're tight on money.
And it's not really 650 watts with the Kicker. They (like most manufacturers) rate on either 13.5 of 14.4 volt electrical systems (not a standard 12 volt system). But you should get at least 600 watts @ 2ohms with it, which is still a great match for an SW8122DVC IMO. ------------- Squirrel
Posted By: bberman1
Date Posted: August 22, 2003 at 9:47 AM
It will defiantly hit I would suggest that you put it in a sealed enclosure with .75-1.0 cu/ft. and give it around 600 watts RMS.
Posted By: pureRF
Date Posted: August 22, 2003 at 2:11 PM
would the kicker SX run the titanium with a 1 farad or would i be better off going with the aluminum. The money isnt a problem on the subs and amp, i just dont want to mess with all the electrical stuff having to do wth the engine and that mess. but would that setup work good?
Posted By: bberman1
Date Posted: August 23, 2003 at 10:55 AM
I would give the Titanium about 800 watts rms. if you only have 600 or so I would go for the Aluminum. But as far as upgrading the Alternator, beside the fact that it is a little on the pricey side. It is a simple upgrade and will not harm your cars electrical system.
Posted By: pureRF
Date Posted: August 23, 2003 at 12:20 PM
im aware of that but my parents are all up tight about just getting the system so the alternator pisses them off. So i guess ill just got with an aluminum. What would be the best amp range to run one aluminum? If i were to get one 15 aluminum would that pound at about 650 (with the SX650.1)? Or would it blow from over powering, because i could run a lower watt amp but i know i wont have a constant 14 volts going to it and thats what the SX is tested at.so my thoughts were the SX and the 15 aluminum would work great together with a 1 farad. any suggestions?
thanks
Posted By: pureRF
Date Posted: August 23, 2003 at 2:52 PM
or the 12 im not sure i didnt know u have to have about 6 cuft for the 15. Is the suggested 3.2 cuft for an aluminum 12 right? (im doin a fiberglass box
