Remote turn-on thump
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17881
Printed Date: April 17, 2026 at 2:22 PM
Topic: Remote turn-on thump
Posted By: pezz92
Subject: Remote turn-on thump
Date Posted: August 21, 2003 at 12:09 AM
Hi there,
I tried using the search function to no avail. on this topic -- I'm using a three amp system (All Orions) that developed a turn on thump when changing the head unit. A Pioneer head unit was removed and replaced by a 1998 factory Volkswagen unit with changer (Panasonic). Another installer I know has seen this before and doesn't think using an inline cap will fix the problem. Anyone have a suggestion to quiet the 'hard' turn-on of the factory unit? Thanks in advance, K.
Posted By: JamesRH
Date Posted: August 21, 2003 at 12:18 AM
what are you using as yout amp turn on? I doubt the factory deck has a proper amp turn on lead...might have to install a seperate togel switch or hook up a relay to your ingition accesory wire so they turn on with the key
Posted By: pezz92
Date Posted: August 21, 2003 at 12:41 AM
This particular radio has provisions for 'active' speakers (individually ampified) -- Therefore is equipped with front and rear preouts and a trigger wire (Blaupunkt actually sells the adapter I'm using to put rca connectors and a trigger wire onto the back of the deck). Everything works and sounds great, I just don't think the radio is equipped with one of the 'soft' turn-ons that modern headunits provide - so I'm looking for a way to delay or quiet the initial turn-on. K.
Posted By: elrayodesinaloa
Date Posted: August 21, 2003 at 1:00 AM
I used a 10k resistor on a blaupunkt amp that I was having that kind of problem with. Don't know if it's going to work in yours but you can give it a try.
Posted By: wvsquirrel
Date Posted: August 21, 2003 at 2:14 AM
It may be that the amps are not turning on/off at the same time as the headunit. Try installing a toggle switch to manually turn the amps on/off while the headunit is already on.
Running 3 amps. Are you daisy chaining the remote line? Most headunits can only supply enough voltage through the remote line to properly turn on 2 amps. For 3+ amps you want to either tap into the ignition harness or use a relay to supply enough voltage to the remote turn-ons.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Posted By: JamesRH
Date Posted: August 21, 2003 at 9:23 AM
as i was saying hook up a relay...posted_image
Posted By: pezz92
Date Posted: August 21, 2003 at 11:12 AM
Yeah.. I should give a relay a chance first.. I'll keep you guys up to date. Thanks for the quick responses, K.
