CVR18 Blown
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17966
Printed Date: April 18, 2026 at 6:02 AM
Topic: CVR18 Blown
Posted By: ull3030
Subject: CVR18 Blown
Date Posted: August 22, 2003 at 10:03 PM
I have a new Kicker Comp VR 18 that only lasted around 20 minutes of use.  I have it hooked to a Bazooka EL1500 (500 watt rms 2ohm).  The sub is a dual 4ohm.  The enclosure is a ported box with a slot port tuned to 33hz.  The internal volume is 5.6875 cubic feet.  The sub still plays but sounds real bad around half volume on up.  Any ideas why this sub did not last longer than 20 minutes.  The time that it did play it sounded great.   Thanks for any help.
Mike
Posted By: c.c.
Date Posted: August 23, 2003 at 9:22 AM
did you go out and beat it hard right out of the box?  if you dont break a speaker in, sometimes they blow early.  a friend of mine had a set of SPL 12" (500 wrms).  he put them in a sealed box, a 400rms x 2 amp (audiobahn) on them and they blew in one hour.
toyota echo...perfect sound named vehicle
Posted By: c.c.
Date Posted: August 23, 2003 at 9:25 AM
it could also be music played below 33hz.  on a ported box,  power handling of the speaker is decreased below the port tuning frequency.
Posted By: bberman1
Date Posted: August 23, 2003 at 11:08 AM
Pull the sub out and check and see if it is actually blown or not https://www.eatel.net/~amptech/elecdisc/vomillia.htm read the part about resistance / ohms it will tell you how to tell if your sub is blown.
Posted By: MAXST
Date Posted: August 23, 2003 at 3:11 PM
could it be the gain is up too high?
I need quality equipment, feel free to donate.
Posted By: ull3030
Date Posted: August 23, 2003 at 5:21 PM
thanks for all the replys
Well the sub is ok, I checked the OHMS and all the connections.  I have two seperate enclosures so I moved the sub to the other side.  Guess what? No problem.  Yeah,  my problem is that the top of the other enclosure was coming apart.  This is the reason why all boxes should have internal bracing.  I guess I, can blame myself for the error because I built the enclosure.  I braced all the inside of both enclosures and reinstalled the box and it sounds great.  Thanks for all your help
Posted By: ull3030
Date Posted: August 23, 2003 at 5:23 PM
I forgot to mention that I forgot to put screws on one side of the top plate.
