wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18032
Printed Date: April 18, 2026 at 6:25 PM
Topic: wiring
Posted By: davywavy4186
Subject: wiring
Date Posted: August 24, 2003 at 9:25 PM
i was wondering like i have a lot of stuff wired in my car and just run a positive and negative to the battery and just put a inline fuse on it i was wondering is their anyway to clean that up so not all the wires r goin to the batter like i can put a power wire to like a box or something then distribute it out and fuses in it too or mayb im just imagininting something i was just wondering but ya wut would u suggest thank u
Posted By: bberman1
Date Posted: August 24, 2003 at 10:35 PM
The way you do it is you run a main + power cable from the battery to a distribution block (the size of the cable will depend on the total watts you have) https://www.darvex.com/miva/merchant.mv?Screen=CTGY&Store_Code=D&Category_Code=DB then from the distribution block you run smaller cables to your components. For the ground you will want it to be as short as possible around 18 inches. What you will want to do is find a metal surface in your trunk sand it down to bare metal and attach a main ground cable. From that main cable you will run it to another distro block and then to your components (be sure to keep your ground as small as possible). Here is a general diagram of how your power cables should be hooked up https://www.crutchfieldadvisor.com/learningcenter/car/S-PCMLzGKeku6/amplifiers_wiring.html (This is using a capacitor, if you do not have a capacitor then just run the wire from the distribution block to the amp).
