New System
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18092
Printed Date: April 18, 2026 at 6:26 PM
Topic: New System
Posted By: wvsquirrel
Subject: New System
Date Posted: August 26, 2003 at 7:06 AM
Thanks to all who have helped increase my knowledge over the last year. My new system is in and sounds great!
Alpine CDA-7995 headunit, (2) 5.25" Infinity Kappa 50.5cs's, (2) 5x7" Infinity Kappa 572.5cf's, (2) Kenwood KAC-649S amps running the Infinity's, (2) Rockford Fosgate RFD2112 Punch HX2's, (1) Rockford Fosgate Power 1000bd amp running the HX2's
I still have to get a HO alternator, build my new enclosure, and eventually upgrade from 4awg to 2 or 0 awg through the firewall. After all the $'s I just threw into my explorer it will be a while though! I'm just happy this system sounds as good as it does. Thanks to all the help you all have given me, I was actually able to pre-determine what type of sound I would get this time!
Thanks again guys
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Posted By: NHSPIKE
Date Posted: August 28, 2003 at 1:11 PM
NO, thank YOU for all the info you've given us!
:O)
spikey
'94 Lincoln, Sony CDX-CA810X, Pioneer TS-A1664/TS-A6963, MTX Blue Thunder PRO50X4, Kenwood KAC-7201, JL Audio 15W4 Sub
Posted By: nedgeworth
Date Posted: August 28, 2003 at 4:08 PM
So when you flying me over so i can have a listen posted_image I think you've been a great help to a hell of a lot of ppl on this forum... special myself so i think i'll be thanking you more. If only ppl thanked you by buying you parts for your system!
Date Posted: August 29, 2003 at 5:22 AM
Thx guys, it's much appreciated posted_image
Squirrel
Posted By: bberman1
Date Posted: August 29, 2003 at 10:00 AM
Sounds to me like you have a good mix of sound with that setup above. When you get it all finished (Although I know I never finish before I start my next one) you need to post pics.
Date Posted: August 29, 2003 at 12:18 PM
Pics of this install, ABSOLUTELY!!! This one has turned out to be my best install yet (at least so far, there's no telling how the enclosure will go!)
Squirrel
Posted By: tdsteele
Date Posted: August 29, 2003 at 6:30 PM
WHat kinda vehicle you got all this in?? Seen something about an Explorer...posted_image
Date Posted: September 02, 2003 at 12:32 AM
'97 Explorer 2-Door Sport. White body, 4.0L SOHC
I figured out my isolator problem... I ended up buying a 200a Stinger relay/isolator. Should get it mounted this weekend. I'm impressed with the factory alternator though, I do have a few problems at idle but once the alternator comes up on speed there's no issues! For once Ford got something right! Still going to do the second battery setup again though. I'm just dreading this enclosure. I'm fairly good with carpentry, but the main concern is with carpeting the damn thing! I've read just about every link posted on here with carpeting an enclosure, but this will be my first time actually working on it. So in keeping in tune with the rest of this install, I'm gonna take my time and try and do it right!
Squirrel
