Powering my amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=19026
Printed Date: May 01, 2026 at 2:20 AM
Topic: Powering my amp
Posted By: hubbabubbamac
Subject: Powering my amp
Date Posted: September 18, 2003 at 10:52 PM
Hey hows it going? For the wire that goes from the battery to my amp is there any already existing hole i can fit the wire through the firewall so that i do not have to drill one? I have a 95 chev cavalier
Andrew
Posted By: profuse007
Date Posted: September 18, 2003 at 11:17 PM
there are usually rubber gromet that goes through the firewall, so use that hole to poke the wire through. besides, drillin is a pain in the ass under there. remember put the sound wires opposite side of the car.
Houston,TX
Date Posted: September 18, 2003 at 11:21 PM
so i should just look under the carpet on the passenger side for some rubber gromet?
Date Posted: September 18, 2003 at 11:32 PM
no, rubber gromet is use at the firewall for weather issues. the firewall is behind the engine, not the floor where the carpet is at. hope it is clear
Houston,TX
Date Posted: September 18, 2003 at 11:38 PM
here are some tips when installin a system:
-always fuse the power wire.
-fuse is place atleast a foot away from the battery
-take out the fuse b4 hookin up the power source to amp
-grounding: use factory ground if exist
            watch out there the fuel tank is at b4 drill
            scrape paint for good grounding
good luck
Houston,TX
Posted By: Ketel22
Date Posted: September 19, 2003 at 11:11 AM
the gromets you will be looking for will usually be behind the dash board it is easier to locate them from the engine compartment.
Quad L Handyman services
Date Posted: September 19, 2003 at 9:41 PM
k well i have my whole dash off right now and i have tried looking for the rubber grommets but i cant really find them, where would you suggest i look?
thanks
Posted By: Ketel22
Date Posted: September 20, 2003 at 5:06 AM
follow other wires through the firewall, i usually trace the wires from the battery to the fire wall when im searching for an existing grommet
Posted By: Ketel22
Date Posted: September 20, 2003 at 5:08 AM
also they are usually found in the extreme left and/or right corners of the fire wall, atleast from my experience.
