SPDT Relay for 3 amplifier remotes
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=1924
Printed Date: May 09, 2026 at 9:25 PM
Topic: SPDT Relay for 3 amplifier remotes
Posted By: blazer88
Subject: SPDT Relay for 3 amplifier remotes
Date Posted: July 13, 2002 at 10:08 PM
 My question is about the SPDT Relay diagram on this site. What I need to know is, first, Do I need this to run ONLY 3 amplifier remote wires and nothing else? And second, What size fuse would I use with only a 600ma draw? Let me know as soon as you can. Thanx, Mark posted_image
Posted By: Velocity Motors
Date Posted: July 13, 2002 at 10:19 PM
Hey Mark, it is a good idea to be using a relay for the remote turn on lead of the amps if you are going to be splitting it to 3 amplifiers. Fuse the lead at 5 - 7.5 amps and this will be sufficient.
Posted By: blazer88
Date Posted: July 13, 2002 at 10:29 PM
posted_image Thanx Jeff, I figured that but had to make sure.
