blowing fuses
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=19389
Printed Date: May 04, 2026 at 12:55 AM
Topic: blowing fuses
Posted By: gold427
Subject: blowing fuses
Date Posted: September 27, 2003 at 7:29 PM
I recently installed a new cd player and now when i turn it up to a mid-high level it blows the fuse under the hood.  Its a 7.5 amp fuse and that is what is speced for the car so i dont think going to a 10 amp fuse would be key.  Prior to the new cd player installed are 2 amps, 200w for the subs and 180w for the mids and highs.  Everything was working fine before the new unit.  Use to have a cd player along with an eq before they got stolen but now with just the cd player in alone i keep blowing fuses like i said at mid high range noise levels.  I also already checked the wiring for shorts and found none.
any suggestions?
Posted By: bberman1
Date Posted: September 27, 2003 at 7:56 PM
What is the make and model of your new Head Unit?
Posted By: NowYaKnow
Date Posted: September 27, 2003 at 8:36 PM
Since most CD players come with a 10 amp fuse in the back of them I don't think that 7.5 amp fuse is gonna feed both your cd player and whatever else is on the circuit. If it comes down to it run a dedicated power line from the ignition harness (with a fuse) to your cd player. Good luck
Posted By: gold427
Date Posted: September 28, 2003 at 7:13 AM
its a pioneer 50wx4 cd player
Posted By: gold427
Date Posted: September 28, 2003 at 7:16 AM
i had an eq and cd player hooked up in there before and it never blew the 7.5a fuse along with the 2 amps and
Posted By: sounds
Date Posted: September 28, 2003 at 9:53 AM
Bottom line is there is no way a 7.5amp fuse can run a head unit at full volume let alone a head unit and a pair of amps  i suggest  you inrease the fuse amperage to at  least  40 amps and see.
puresound
Posted By: Velocity Motors
Date Posted: September 28, 2003 at 3:41 PM
Do what NowYaKnow suggested an run a designated power wire for these components. If you just keep increasing the amperage of the fuse on the same wire, you run the risk of a fire or melting the wiring that the components are attached to.
Posted By: sounds
Date Posted: September 28, 2003 at 4:49 PM
I seem to be missing something here,you said you have two amps and a eq on the original hook-up so therefore ,the fuse that is being blown is it coming off a main power wire that you installed  to run the entire system or is it the factory installed fuse in that black box that also houses the headlamp fuses and relays.
puresound
Posted By: LAUR
Date Posted: September 28, 2003 at 10:59 PM
Check  the ground wire .
Posted By: CruisinS&S
Date Posted: September 29, 2003 at 11:42 AM
check all of your speaker wire connections too. If they are out of phase that result in a blown fuse at high levels
Cruisin Security And Sounds
Posted By: superstreet786
Date Posted: October 07, 2003 at 8:23 PM
try the bigger fuse but if that blows you will know there is some electrical problem
