Drop-in speaker : Chrysler Concorde 2003
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=19511
Printed Date: May 06, 2026 at 12:48 PM
Topic: Drop-in speaker : Chrysler Concorde 2003
Posted By: crazyray
Subject: Drop-in speaker : Chrysler Concorde 2003
Date Posted: September 30, 2003 at 5:08 PM
I'm looking for a recommended "drop-in" speaker for the front doors in this car. The size appears to be 6 3/4" with a 3-screw mounting pattern. The car has a stock non-Infinity system with stock midbasses in the doors and stock "tweeters" on the sail panels (these will be removed). The new system will use an aftermarket amp so power will not be an issue. I'd like to avoid running new speaker wire into the doors so speakers with separate passive crossovers are out.
Recommendations?
Posted By: Sweekster
Date Posted: September 30, 2003 at 8:15 PM
According to crutchfiled these will fit your car.  I don't think there are any "drop in" replacements though (although someone else in this forum may be able to find some for you).  What i would do is make an adapeter ring out of wood or mdf  (maybe 1/4 inch) and screw that to the factory holes and then attatch the speaker to the ring.
Duane...
If you think you're confused, imagine how you feel.   posted_image
Posted By: crazyray
Date Posted: September 30, 2003 at 10:27 PM
Thanks for tryin', Duane. I had looked at those and the Pioneers listed on Crutchfield's site. I was just hoping there might be someone with some experience with this car. As it stands, I plan to make adapters from wood, in part because I suspect I'll need the extra depth. We'll see.
