broken circuit?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=19527
Printed Date: May 06, 2026 at 6:13 PM
Topic: broken circuit?
Posted By: samstown
Subject: broken circuit?
Date Posted: September 30, 2003 at 9:29 PM
ok...2000 corolla here...bought a Premier DEHP350B and went to install....stockdeck has the double harness thing goin on....the power harness has a red, a black, a yellow, a tan, and a tan-green....connected power to yellow, acc to red and ground to black....nothin
i wasnt sure which to connect the ill wire to since there wasnt any power to begin with....then i noticed clock on dash wasnt working...or the dome light...checked the fuses and theyre all good...tried reinstalling stock deck and still nuthin...
friend suggested the clock and dome light are psooibly circuited thru the deck somehow...is that possible?
what should i do...or am i being a total n00b and forgetting something obvious?
thanx guys
Posted By: italnpimp59
Date Posted: September 30, 2003 at 10:13 PM
did you not buy the wire-harness for that vehicle?
Posted By: auex
Date Posted: September 30, 2003 at 10:15 PM
Stock colors do not match the aftermarket radio harness. You need to test to find out what wire is what. Also you blew a fuse.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: samstown
Date Posted: September 30, 2003 at 10:32 PM
no i have the harness....
i didnt blow a fuse because i checked them all....any other ideas?
I live my life in halves...half of me here...half of me still in Norrath.
Posted By: Ketel22
Date Posted: October 01, 2003 at 2:11 AM
even if you have checked the fuses you may want to replace them, if you have not refered to a wiring diagram you may want to.
Quad L Handyman services
