wiring through firewall
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=1985
Printed Date: May 10, 2026 at 5:07 PM
Topic: wiring through firewall
Posted By: cadavis
Subject: wiring through firewall
Date Posted: July 16, 2002 at 2:10 PM
Anyone know of a good spot to run the power wire from an amp through the firewall of a 99 Sierra truck? I've looked and haven't found any good spots... I'm stuck.
Posted By: GlassWolf
Date Posted: July 16, 2002 at 2:46 PM
usually there is a spot on the driver's side of in about the center with a large rubber grommet you can use.
If not, you can make a hole yourself and insert a grommet. companies like partsexpress.com sell grommets just for doing this.
-GlassWolf
Pioneer Stage-4, Orion, DynAudio, Fi
