Can someone help on a firewall question?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=19897
Printed Date: May 09, 2026 at 9:22 AM
Topic: Can someone help on a firewall question?
Posted By: Dis0wned
Subject: Can someone help on a firewall question?
Date Posted: October 09, 2003 at 10:22 PM
I need to get through a 2001 honda civics firewall and I have no idea where I can get through
please help
thanks
Posted By: chriswallace187
Date Posted: October 09, 2003 at 11:00 PM
if the car is an automatic, you can look to the left of where the brake pedal goes through the firewall and see a plate where the clutch would be. That's always a good spot to drill. If it's a manual, just look for a spot that's in the open on both sides of the firewall.
Posted By: mbiker1
Date Posted: October 13, 2003 at 9:31 AM
 also there is a spot to the left of the sterring collumn but it is with the wire for all the powering of the interior so make sure to disconnect the battery and also use a snake.
