66 microbus!
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20172
Printed Date: May 06, 2026 at 10:39 AM
Topic: 66 microbus!
Posted By: Ketel22
Subject: 66 microbus!
Date Posted: October 16, 2003 at 2:14 AM
within the next month i will be trying to install a sound system in a 1966 VW microbus 7 seater. i havent seen the vehicle yet but ive been told that a marine owned it before and had done some jerryrigging, and cut some extra holes to add speakers without removing stock speakers. im just looking for all the specs of the stock stereo system (speakers, speaker location, and wires ill most likely have to deal with in dash) of the 66 microbus if there was any. ------------- Quad L Handyman services
Posted By: Ketel22
Date Posted: October 16, 2003 at 8:39 PM
nobody has ne clue about the vehcile?
Posted By: bugluvr38
Date Posted: October 22, 2003 at 5:07 AM
wow, didnt expect to see another fellow vw enthusiast here, or are you just doing the install? well, one important fact about a 66 microbus: stock is 6 volt. it has probably been converted to 12 volts if its still on the road, tho. but what that says is that whatever wires there were (if any, am radio isnt an option seen too often) have probably been altered, spliced, burned up, replaced and everything else. but one thing that is on your side is that the wiring in the bus (unless someone has really altered it) is so simple that you could probably completely rewire the whole thing in a few hours. sorry i cant be more help, but most likely the wiring will be different from any other, as most of them are. but let me know how it goes. good luck.
------------- oh, god... what did i do now??
Posted By: Ketel22
Date Posted: October 23, 2003 at 2:16 AM
yeha, im just doing the install, my pal the owner just loves his microbus, he owns the only one on the island and in the process of refurbing the interior, exterior has been repainted and in mint, like i said tho i havent seen it myslef. but as far as the wiring, 6v converted to 12v? and a gi got to the system before me so im guessing that means ill have to pull all the wires and replace with whats needed. ------------- Quad L Handyman services
Date Posted: October 23, 2003 at 3:29 AM
yeah, im sure if hes done that much work to it, then it has been converted to 12v. the wiring may not be that bad, either. you best bet is to just wire everything straight into the fuse box (ign., 12v). i have found that there are usually several open terminals that will have constant power, and a few with power ign. on only. with the proper connectors, you can just wire right into the fuse panel. and if the owner really cares about his bus, which it sounds like he does, you might want to consider mounting the head unit under the dash with one of those plastic mount-anywhere boxes. the factory hole in the dash will be too small for a standard din-style head unit, and i doubt he wants the dash cut up, or even the factory blocker plate (if there is no radio) removed. as far as speakers, the door panels will work, provided that the mounting depth is fairly shallow. you wont have to worry about window clearance, though. i cant think of any more tips off-hand. if you have any other questions, let me know; i may or may not have a suggestion or answer. ive done installs in a lot of bugs, and a few buses, too. well, good luck!
Posted By: Ketel22
Date Posted: October 24, 2003 at 2:46 AM
thank you!
