Small sub enclosure
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20635
Printed Date: May 04, 2026 at 7:12 AM
Topic: Small sub enclosure
Posted By: csq33r
Subject: Small sub enclosure
Date Posted: October 27, 2003 at 11:17 AM
I've built a sub enclosure that is too small.  The space available in my car has dictated the size of the box.   I have an 8" Clarion SRW2081.  The box size is .28 cu. ft. (with displacement of the sub factored in).   I do not have any other components yet.   Any idea how this sub will act in this sealed box.   I have zero experience, so I don't know what to expect.   Would the sub need more power, or less power in such a small box?  The sub can handle 300w max, and should be in a sealed box of .48 cu. ft.  This box is positioned between the occupants (2 seater), so doesn't need to be very loud.  Any suggestions as to how much power I should shoot for when selecting an amp to power this thing, and what to expect, would be greatly appreciated.  Also, is there a crossover point that is safer when dealing with a too-small box?
Esprit907
Posted By: Velocity Motors
Date Posted: October 27, 2003 at 12:11 PM
Fill with dacron filler or go to a fabric store and use polyester filler . This will fool the sub into thinking that the enclosure is about 20 % larger than it really is. Fill the enclosure about 3/4 full with the filler.
Posted By: Ketel22
Date Posted: October 27, 2003 at 7:49 PM
if you can get another sub in there i might suggest an isobaric set up. you'll have to buy another sub for this but it should be worth it.
Quad L Handyman services
