New Battery suggestions?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20716
Printed Date: May 05, 2026 at 5:50 PM
Topic: New Battery suggestions?
Posted By: 1UZFE
Subject: New Battery suggestions?
Date Posted: October 29, 2003 at 12:14 PM
hey everyone,
i'm in the market for a new battery for my 1993 LS400. i'll have a small system in the trunk and i'm gonna ask people at  the "clublexus" forum which they recommend and hopefully one will cross-reference.
so that's it really. which battery do you recommend?
thanks,
d
Posted By: fuseblower
Date Posted: October 29, 2003 at 12:35 PM
What kind of system do you have.  You might be able to use a regular battery.
AMP, RADIO, SUB etc...
Posted By: 1UZFE
Date Posted: October 29, 2003 at 12:55 PM
just a simple 12"JLw4 with a 150W lightning Audio amp.
Posted By: Ketel22
Date Posted: October 29, 2003 at 6:45 PM
kinda under powering it arent ya? i think you should have no problem just using a standard battery
Quad L Handyman services
Posted By: Ishinc
Date Posted: October 29, 2003 at 7:59 PM
hey, i'm a member of clublexus too! what a small world. my battery just died and i changed it to a red top optima. a oem lexus battery is about 80 dollars so i just spent alittle more for a better battery. i hear nothing bad about these batteries and it's supposed to last longer. you might be able to get a good price at costco.
Posted By: wvsquirrel
Date Posted: October 30, 2003 at 3:41 AM
An Optima Red top is a good battery to go with.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Posted By: bberman1
Date Posted: October 30, 2003 at 8:25 AM
I would suggest a Hawker Odyssey battery https://www.odysseyfactory.com/ody_why.htm   they manufacture all the batteries for Stinger
https://www.sounddomain.com/shoplist~b~Stinger~t~Batteries as well as the military. Since Optima was bought out by Interstate a few years back I think their quality has gone down hill. If you put the 2 manufactures side by side and compare specs on the batteries the Hawker comes out on top.
Posted By: premieravp
Date Posted: November 03, 2003 at 1:31 PM
It's funny, but SOund domains own rating system has the Optima rated higher than the Stinger. You can beat Optima dollar for dollar. If you are going to listen to your system a lot with the engine OFF, go for the yellow top, otherwise get the red top. OE Toyota batteries are small and made strong enough for ONLY OEM 100% factory cars.
Posted By: forbidden
Date Posted: November 03, 2003 at 2:14 PM
Premieravp is correct, follow his advise on which battery to choose.
Posted By: bberman1
Date Posted: November 03, 2003 at 2:57 PM
Premieravp you might want to read car sounds review of the two batteries  (Stinger)  https://www.carsound.com/reviews/power/Power2dB.html (Optima) https://www.carsound.com/reviews/power/yelltp.html But disregards to what the reviews above say, if you compare specs between the two battery the Stinger/Hawker will give you the most power.
Posted By: superstreet786
Date Posted: November 03, 2003 at 6:19 PM
You can probably use a regular stock battery for that
---- 1996 Chevy S10 ----
1 Lightning Audio S2.600.2 Amp
2 Lightning Audio 12" Subs
1 Lightning Audio 1 Farad Cap
