Installing audio system in 2003 GTI
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20802
Printed Date: May 04, 2026 at 7:11 AM
Topic: Installing audio system in 2003 GTI
Posted By: Geisha_Gyrl
Subject: Installing audio system in 2003 GTI
Date Posted: October 31, 2003 at 8:53 AM
Hey, I wanted to know what all needed to be done to install a new head unit, amps, and subs in a 2003 GTI. It comes with the monsoon system. Thanks.
Posted By: Velocity Motors
Date Posted: October 31, 2003 at 9:00 AM
You will most likely want to use the OEM wiring if you can ( this will reduce your install time ). The OEM amplifier will need to be turned on or bypassed at the output side of the amp. I suggest using new wire all around , but that's just me.... do it right the first time and you don't have to worry about it.
