91 ford econoline van
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20815
Printed Date: May 04, 2026 at 12:30 AM
Topic: 91 ford econoline van
Posted By: italnpimp59
Subject: 91 ford econoline van
Date Posted: October 31, 2003 at 5:39 PM
ok heres a tricky one.  i got a 91 econoline van in the shop today for a new headunit.  well after i wired it all up, i got no output from speakers.  so i start testing pairs of speaker wires for ohm loads and i got weird numbers like 55 and 67 ohms.  so i looked behind the ford harness(factory side).  this harness has 8 wires, two for each speaker, but on the factory side it only had five.  four for the positive wires and ground so i realize the speakers are common ground.  so i grounded all 4 negative speaker wires and still got nothing! i looked around and found what im pretty sure is a factory amp way back in the dash to the right.  im wondering if there is a way to bypass that amp or if I have no choice but to run new speaker wires to each speaker.  i set her up an appiontment for sunday.  i couldnt do it today bc i had other appointments waiting for me.  what was supposed to be a 20 min headunit install is now possibly an hour of running speaker wires.  if anyone knows a way to bypass that amp please let me know!  thanks
Jimmy
Posted By: forbidden
Date Posted: November 01, 2003 at 2:22 PM
Jimmy, I ran into this one many moons ago and had to rewire all speakers, stbu right about now, bite the bullet, get er done and one more happy customer.
Date Posted: November 01, 2003 at 6:59 PM
well shes coming back tommorrow.  i guess ill be running speaker wires....that sucks, i hate doing that, but i gotta keep the customers happy.  thanks.
Posted By: speedwayaudio1
Date Posted: November 02, 2003 at 10:05 PM
did you check for a factory mute? should be a blue wire that needs 12 vdc. i had the same trouble from a 92 explorer.
Big Dave
