Rear Speaker Weakness
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20894
Printed Date: May 02, 2026 at 1:30 PM
Topic: Rear Speaker Weakness
Posted By: edieckman
Subject: Rear Speaker Weakness
Date Posted: November 02, 2003 at 3:45 PM
Just installed a new headunit in my 1992 4-runner, everything seems to work fine, but the sound to the rear speakers is very, very weak with virtually no bass or mid.  I rechecked the connections and everything seems to be fine....front speakers put out full sound. No amps or crossovers are being used....any suggestions?  Thanks.
ike
Posted By: MAXST
Date Posted: November 02, 2003 at 3:47 PM
set the fade more so to the rear.
I need quality equipment, feel free to donate.
Posted By: forbidden
Date Posted: November 02, 2003 at 3:59 PM
Some 4 runners have a hidden amp for the rear speakers. If memory is correct hook up the remote on lead from your cd to the amp turn on wire in the factory harness behind the radio, should solve the problem.
Date Posted: November 02, 2003 at 4:15 PM
I'd adjusted the fade all the way to the rear, but the sound was still extremely weak.  There was an amp in the front of the vehicle with the original factory headunit, but I removed that amp with the old stereo.  Any idea where the rear amp would be located in the vehicle?
ike
Date Posted: November 02, 2003 at 5:16 PM
Can't remember off hand, did you try the amp turn on wire? My toyota has no fewer than 4 hidden amplifiers. As a last resort you may have to wire the speakers directly. The speakers should be 4" and mounted in a box behind the panels. It takes a little time to remove these panels, you may just find the amp back there as well
Posted By: Alpine Guy
Date Posted: November 02, 2003 at 9:31 PM
Nissan pathfinders are basically the exact same at 4 runners, and in the pathfinders, the amp is located on the right side of the rear of the vehicle above the wheel whell, , , ,behind the the panel.
