Annoying Noise
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20925
Printed Date: May 02, 2026 at 6:11 AM
Topic: Annoying Noise
Posted By: Liberty555
Subject: Annoying Noise
Date Posted: November 03, 2003 at 1:47 AM
I have recently installed an amp and sub into my car, and (i think) have all the wiring right as its works great, but when I switch it on (the car stereo) there is a "pop" noise from the sub, and a quieter "pop" when I switch it off again.
What can I do to avoid this? Is it because the amp gets a voltage spike when the ignition is turned on, or is it as the key is turned through ACC to ON?
Its quite annoying and I've really gone for a system that looks standard but performs well, and nothing gives the game away more than tha noise from the sub!
Thanks in advance!
Posted By: bfog99
Date Posted: November 03, 2003 at 10:48 AM
check you ground. make sure that it is attached to a solid piece of bare metal. no paint, no plastic, just bare metal.
