93 corolla seca wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20979
Printed Date: May 02, 2026 at 7:13 AM
Topic: 93 corolla seca wiring
Posted By: konfused
Subject: 93 corolla seca wiring
Date Posted: November 04, 2003 at 2:41 AM
hey
im putting a cd tuner into a 93 corolla seca, and i ran into some problems cause the wire colours are not the same as the ones listed in the database.
heres the ones i have, i was wondering if someone could make sense of them
light green and light green - white stripe
purple and purple -white stripe
yellow nad yellow -white stripe
blue and blue-white stripe
black and white stripe
dark green
Blue and yellow stripe
dark green and red stripe
i think the top set are speakers, im just not sure what ones, and im just trying otfigure out what the bottom ones are.
thanks
-konfused
Posted By: forbidden
Date Posted: November 04, 2003 at 1:48 PM
Use a meter, eliminate any power, ignition and ground wires. Check for impedance on the other leads. Does the car have a power antenna? Did you also cut the factory harness off or do you still have it?
