explorer power antenna
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21174
Printed Date: April 30, 2026 at 5:01 AM
Topic: explorer power antenna
Posted By: DEIman
Subject: explorer power antenna
Date Posted: November 08, 2003 at 5:16 PM
i recenty installed a blaukpunkt deck in a 98 explorer and i ran new wires 2 bypass factory amp...the only problem i have is the power antenna in rear control unit....i found 2 wires in the passenger kick panel...if u send 12 volts to one and gronud the other it goes up...then if u switch 12volts 2 the other one and ground to the other one it goes down....is there a relay diagram 2 make this work someone please help me
Posted By: auex
Date Posted: November 08, 2003 at 5:32 PM
Just hook up the amp/ant lead up behind the deck. What you have is the motor wires going to the power ant.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
