multiple amps and remote wires
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21184
Printed Date: April 30, 2026 at 9:38 AM
Topic: multiple amps and remote wires
Posted By: Lasher
Subject: multiple amps and remote wires
Date Posted: November 09, 2003 at 1:21 AM
If i were to hook up 2 or more amps how would i wire the remote wires (usually the blue wire on the H/U)  of multiple amps with out burning out the H/U? I heard I would have to use a relay to do this is this correct and if so how would i wire it up?  Also would I need a relay for each additional amp? or can one relay be used for 2 or 3 amps? Thanks in advance for any info.
Posted By: Lasher
Date Posted: November 09, 2003 at 1:39 AM
MY bad I see someone has asked this question about multiple amps and remote turn on wires. Let me know if this is correct.  They say it is possible to run one remote wire from H/U to one amp then run a second wire from the 1st amp to the second amp basically saying i could daisy chain them is this correct? If so is this possible when adding a 3rd or 4th amp? Thanks again for any info.
Posted By: DYohn
Date Posted: November 09, 2003 at 8:38 AM
Daisy-chaining is OK as long as you do not overload the HU circuit.  Most HUs will output a couple of amps on the remote lead and most amps draw a few miliamps, so you are generally safe to switch two or three pieces of equipmnet (amps, crossovers, etc.)  If you start adding on four or five or more, or if you add fans or other switched equipment, you will definately want to add a relay and fuse block.  One relay will do the trick for everything, again depending on the total current draw you are powering.
Posted By: Lasher
Date Posted: November 09, 2003 at 12:20 PM
Thanks DYohn your info has been very helpful.
Posted By: superstreet786
Date Posted: November 09, 2003 at 1:02 PM
what i do is i just have a 12v power source hooked up to a switch but for the H/U just make that one wire split off into 3 remote wires
---- 1996 Chevy S10 ----
1 Lightning Audio S2.600.2 Amp
2 Lightning Audio 12" Subs
1 Lightning Audio 1 Farad Cap
