signal in put before and after epicenter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=2132
Printed Date: March 26, 2026 at 5:41 AM
Topic: signal in put before and after epicenter
Posted By: want more power
Subject: signal in put before and after epicenter
Date Posted: July 22, 2002 at 4:27 AM
i have a epicenter for my bass but also have a low output on pre amp and a low output on crossover and alow ouitput filter on amp my ? is do i run with filters on or off on amp on pre amp before the epicenter? and do I run my amp on mono or stereo mode I have the amp bridged an I am only running subs two of them of of it
------------- thanks a watt
Posted By: GlassWolf
Date Posted: July 22, 2002 at 4:36 AM
read the directions for the EpiCenter, but if I recall from the one I used to have, you install it just before the sub amp. it replaces lost bass from things like radio broadcasts where frequency response is narrowed and sound is lost.
------------- -GlassWolf
Pioneer Stage-4, Orion, DynAudio, Fi
Posted By: lil_joker2k2
Date Posted: July 22, 2002 at 8:27 PM
------------- George
Date Posted: July 22, 2002 at 8:32 PM
From my personal experience. If you are going to be using an epicenter I would with an Eq. I had problems when I had it with a crossover. but for your info you can put it after an Eq but BEFORE a crossover. The reason i think an Eq is better is because diffrent music has diffrent bass and its much more easier to mess with an eq than messing with the crossover in the back. good luck
